For those that are curious hat a 40 year old truck looks like
You shouldn't need to remove the hub. There should be enough room behind it to knock out the old ones and slip the new ones in and torque them down.
Good looking Jeep. It's a keeper.
actually, after getting the hub in the shop and working on it for more than an hour, I had one lug moved about 1/4 inch. I'm going to have to find a shop that can get them out and put the new ones in place.
Are they threaded in or pressed in? If they are pressed in you'll need someone with a 10 ton press.
I've always had luck with some penetrant and a hammer or an air chisel with a punch in it to take them out. It wouldn't take 10 tons for sure.
If you heat the lugs with a propane torch it makes them easier to remove. Helps break the rusted build up. If it is threaded make sure that it is not left hand thread like older Dodges used to be.
No threads, but there seems to be a reverse taper on these things. I'll try to get a pic of what I'm talking about. Another FSJ (full size Jeep) guy said that they weren't meant to be removed and had to take a grinder to them to remove the reverse taper. I may try to find a replacement hub and just have to install the new ones. We'll see.
Frank, While not truely Rare, they aren't under every bush anymore.
The engine is a Buick 350 so parts are readily available since that engine was in the Jeep trucks/wagoneer for several years asa well as the Buick cars for many more. But it's not the same as the Chevy 350 that's available EVERYWHERE.
The body parts are a bit harder to find now. The front half of the trucks and wagoneers (the original full sized versions, not the wannabe XJ-Cherokee version) was identical from the mid 60's through to 91 (last year for the Grand Wagoneers), so I can get body parts from any of those that I can find. There is a small outfit that makes replacement panels for the beds and other parts too, but they are more expensive obviously.
Axles, tranny and transfer case were all Dana if I remember correctly, so while improved versions came around later, they are damn tough.
Since there;s nothing complicated involved (no computer, no AC, no power steering or brakes), just a bare bones Truck, there's just not much to it.
I've now even been told that the hub I need was the same one used on the CJ's of the same era, so they shouldn't be hard to find if I mess this one up.
That's what Kaiser was known for, Taking the best parts available and blending them together into nearly indestructable vehicles. 1970 was the last of the Kaisers.
