Any POWER POINT gig here
Darley
Hervey Bay Queensland
OK, computer is not my things but I have to help my son project in Power Point this will be a Narrative Slideshow including background, transition, effects, formatted text, change to layout, pictures and hyperlinks, all is fine beside the hyperlinks, I copy and paste the link to the slideshow but they are not active I mean that the teacher want to click on the link in the slide to see where the photo(s) or background come from, my question is how can you make an active hyperlink? does one know how to add music in the slide show, any help will be appreciated, Thanks
For the hyperlink:
1. type in your web address as text...(http:\\www.penturners.org)
2. highlight the text containing your web address
3. Click on (in the menu bar) Insert, Hyperlink (or the keyboard shortcut is Ctrl+K)
4. Type in the web address in the Address section of the Edit Hyperlink window.
The hyperlink is only active while the slide is being viewed as a slideshow. The hyperlink is not clickable in the "Normal" view.
This is in PowerPoint 2002 SP3.
For music in the slideshow, do you have a song/music clip that you want to play for the whole slideshow or do you have different sounds that you want to play on different slides?
Not knowing which version of PowerPoint you're using makes these questions a little tough to answer specifically. I will tell you that a hyperlink in PowerPoint actually links to another slide in the presentation. I don't belive it will work like a hyperlink in an email. One way you could handle this is to have a text box with the photo source, credits etc appear just before you advance to the next slide. This is very simple to do. As far as adding music, that depends on if you want one wav file for the entire presentation or different wav files for different slides. The easiest way to instruct you is to suggest that you open up the presentation while the computer is attached to the internet. Then simply hit the F1 key to start the online Microsoft help. From there just type in what you want to do and it will provide the directions.
Sorry I couldn't be more specific. I use PowerPoint 2007 and I have just about completely forgotten how to use PowerPoint 2003 since it works very differently.
I hope this helps.
Jim Smith
Now you are going to confuse him! :wink: :biggrin:
LOML was about ready to throw her computer at me when I asked her that question once - after an hour's worth of PP explanation.
powerpoint
This is Don's "lady".... THIS SHOULD HELP YOU. I use PPT 2007. I didnt see what version you are using. Copy and paste this info into a Word doc and print it out... ruth
What do you want to do?
Create a hyperlink:
To a slide in the same presentation
To a slide in a different presentation
To an e-mail address
To a page or file on the Web
To a new file
Create a hyperlink to a slide in the same presentation
1.[FONT=&quot] [/FONT]In Normal view, select the text or the object that you want to use as a hyperlink.
2.[FONT=&quot] [/FONT]On the Insert tab, in the Links group, click Hyperlink.
3.[FONT=&quot] [/FONT]Under Link to, click Place in This Document.
4.[FONT=&quot] [/FONT]Do one of the following:
§[FONT=&quot] [/FONT]Link to a custom show in the current presentation:
1.[FONT=&quot] [/FONT]Under Select a place in this document, click the custom show that you want to use as the hyperlink destination.
2.[FONT=&quot] [/FONT]Select the Show and return check box.
§[FONT=&quot] [/FONT]Link to a slide in the current presentation:
§[FONT=&quot] [/FONT]Under Select a place in this document, click the slide that you want to use as the hyperlink destination.
Top of Page
Create a hyperlink to a slide in a different presentation
3.[FONT=&quot] [/FONT]Under Link to, click Existing File or Web Page.
4.[FONT=&quot] [/FONT]Locate the presentation that contains the slide that you want to link to.
5.[FONT=&quot] [/FONT]Click Bookmark, and then click the title of the slide that you want to link to.
Top of Page
Create a hyperlink to an e-mail address
3.[FONT=&quot] [/FONT]Under Link to, click E-mail Address.
4.[FONT=&quot] [/FONT]In the E-mail address box, type the e-mail address that you want to link to, or in the Recently used e-mail addresses box, click an e-mail address.
5.[FONT=&quot] [/FONT]In the Subject box, type the subject of the e-mail message.
Top of Page
Create a hyperlink to a page or file on the Web
3.[FONT=&quot] [/FONT]Under Link to, click Existing File or Web Page, and then click Browse the Web
4.[FONT=&quot] [/FONT]Locate and select the page or file that you want to link to, and then click OK.
Create a hyperlink to a new file
2.[FONT=&quot] [/FONT]On the Insert tab, in the Links group, click click Hyperlink.
3.[FONT=&quot] [/FONT]Under Link to, click Create New Document.
4.[FONT=&quot] [/FONT]In the Name of new document box, type the name of the file that you want to create and link to.
If you want to create a document in a different location, under Full path, click Change, browse to the location where you want to create the file, and then click OK.
5.[FONT=&quot] [/FONT]Under When to edit, click whether you want to edit the file now or later.
Top of Page
See Also
[FONT=&quot]
[/FONT]Add an action button
[FONT=&quot]
[/FONT]Add text to a slide
For a complete description of how to incorporate sound into the presentation, view the details here.
Different ways to use hyperlinks can be found here.
Overall online help for PP2003 is found here.
Thanks to every one for they input(s) my son Power Point will be presented amongst the rest of the class, it as been a great learning curve in Power Point, the end result is a slide show of 19 slides with different photos, story, effects, background, hyperlink and music total 10MB. I'm proud of him he did a great work, will know the result and is notation on the project this afternoon when I will pick him up, BTW is only 10
