Glue in tubes
aggromere
Tampa, FL
I have been gluing tubes into blanks using medium CA and it has worked fine. The little that gets in the end of the tubes I just scrap away with an exacto knife.
I tried gluing 10 tubes (for 5 Jr. Gentlemen) and I wanted to make sure the tubes were tight so I used Thick CA. Now my tubes are full of glue. I was able to scrap one set and get it on the bushings but the others are taking a long time.
Does anyone have a method they use to get super glue out of the tubes after they have been glued in? and, what do you guys do when gluing tubes to avoid this problem.
I use this to avoid most of this sort of mess:
http://arizonasilhouette.com/Base_PLate_Wax.htm
and what gets in the way afterwards, I use the inside (i.d.) measuring jaws of a set of junk dial calipers to scrape the rest of the way clean.
just hold a little pressure on and twist back & forth to scrape it clean.
the calipers are (of course) adjustable to any size tube.
That's what works for me!:biggrin:
for some reason, I rarely get glue in the tubes, so I haven't tried any plugging methods. I do have a three sided de-bur knife from my machinist days. it is sturdy, sharp and does the trick nicely. also cleans the edges a bit after facing.
I've used baseplate wax for a long time, it works great. I get it free from my Dentist! If I get a bit inside (it happens) I use a dremel tool with a thin sharpening stone, and it works great. But I like Johnny's idea a lot! I'm tryin' that one soon.
Dale
Hello,
I have used a round file inside to get the glue out. I don't reccomend it as a regular practice though as the this sometimes alters the internal tube dimensions which has an impact sometimes when you press the parts together.
An ounce of protection is worth a pound of cure so I reccomend baseplate wax as well...
Nick
We put the glue on the tube so none gets in when you slide it into the blank. I just carefully wipe the one end to remove the excess before it dries.
I have taken a drill bit that just matches the I.D. of the tube and used it as a reamer inside the tube. I have the HF set of 105+ sizes, so it makes it easier to find what size I neeed (use a caliper). I then take a shotgun cleaning rod with the appropriate steel brush (Wal-Mart special) and clean out the tube. Be carefull not to really ream/scratch up the insides, I have increased the I.D. of the tube so that it didn't seat the transmission or cap as tight as it could of. Good luck.
I don't plug my tubes and I use thick CA. I only get very little glue in them so I'm not sure why you are getting so much in there. I use a round file to get it out. Just takes a few seconds.
I am using Super Epoxy and almost never have problems with glue inside. And as said before the brass .22 kal is a wonderful equipment to clean the inside with.
Steinar NORWAY
I also put the glue on the tube. When I use my pen mill to square the blank the shaft on it usually takes care of anything that might create a problem. I know this might not work with some of the bigger kits but it has worked fine for me so far.
To each their own, but I find that if I put the glue on the tube and push it (the tube) into the blank from just one end, then I get a large amount of glue at that end and very little at the other. I blew out a blank once after doing this and turned it down to examine the glue reside - very much at the "push in" end and not so much at the other end. So now I plug the tube, put glue on it, push it 1/2way into one end while twisting, then turn the blank and push it in from that end. Much more even glue profile.
Oh yeah, when I do have glue in the tube, I try to use a drill bit to ream it out, but it's not been a giant problem for me because I started plugging the tubes (use potato, since it's available and I've yet to order some wax...)
daniel
Ive started putting paste wax on the inside of my tubes before I glue now. I glue them up and then give them a quick hit of accelerator. Then I clean the glue out of the ends (mostly at one end) with my xacto knife. Even though there is still glue in now comes out pretty easily.
I put a dab of mineral oil on a qtip and wipe the inside of the tube before gluing. I have a D drill mounted on a wood handle to remove any glue inside the tube. I do not twist the drill inside the tube, but stroke it in and out. 5 or 6 strokes usually causes the glue to pop out.
