using testors?
spitfire
bloomsburg,pa.
So I haven't been around for a while because I have had other things going on. I started making beer taps from poured resin. I see some people are using testors paints. Is there any change in the process in using the paint over say PearlEx powders? I thought I read before that using paint makes the resin setup quicker, is that true?
I actually use 1.5" PVC for my tap molds. Here are the first 2 I did. I have 3 more I am working on now. I need to mix the colors a little more next time but I was happy with the results.
I pour both colors at the same time. What I did on the last ones was put a skewer down the middle and swirled a little when I pulled it out. I will be turning those tomorrow so I will report back with pics to show the results.
DOes anybody have any info for me on the testors paint? I went to Walmart last night to buy some and they don't even sell it anymore
Some time ago there was a thread about tap handles. Bar supply places sell the threaded fitting for the tap handle. I don't remember what the thread is, but it is standard for all taps and handles.
I have all the fittings I need, I am actually jut asking about casting with testors paints.
I wish Walmart would have had it so I could try it. I think I am going to go out today and try to find some and see what happens. If I do I will report back.
check hobby lobby or Michaels. I bought a set from hobby lobby for painting the inside of the blank.
I also would like to know if you can use the testor paints with PR.
I havent used testors paint, but I did use some of my wifes finger nail polish once and it worked fine. It was dark green with a pearl shimmer and cured like it should.
it's really funny how no one is answering your question. not even me.:biggrin: I use powders. wally world don't got testers. I saw a bunch today at micheal's. I know you can use the paint,but as far as how it reacts, I don't know, sorry.
I know, what's even more funny is the fact that people here have used it but aren't speaking up :(
Oh well, I like to try new things anyways. I should have the paint Monday and results soon after.
I use Testors Acrylic paints and PearlEx powders at the same time. I just free pour and dump in a little of the PearlEx powders. I'll try and get some pictures posted. I have not found that it speeds up the curing process. I always wait at least 24 hours before taking them out of the molds.
How do you cut the threads for the tap handles?
I generally cast with alumilite, I use testors oil paints. The testors paints give a solid color, where as the pearlex powders are translucent. If you mix the two together, you get a more solid color but still has the pearl. The more paint, the more solid the color. No doubt there comes a point when you can use too much paint. With alumilite, it would require far more paint to be too much because alumilite chemically bonds with paint, and I don't think PR does, or at least not in the way I'm talking. IE..if you paint inside your mold, then pour clear alumilite in the mold, the alumilite will bond chemically to the paint, meaning the alumilite will have that color on the outside of it and it will not scrape off unless you go pretty deep with your scratching. This is one of the special traits of that product. So you can make lets say a doll head, you paint the mold, not the head. You pour the mold and have a perfect head, pre-painted, but the paint won't flake off and it's super shiny because it has just come out of the silicone mold. When alumilite is sanded, that's when it becomes harder to recover the gloss.
I don't cut the threads for the taps I use an insert.
You should be able to find Testors Acrylic paint at any model shop. I get mine from a local Hobby Town specializing in models, RC planes, slot cars and the such. They have a large selection and stock always seems to be fresh.
What kind of insert and where do you get it?
Never used Testor's, but I may give it a try. I started with Mixol, which someone said had no fillers and was better, but frankly it's limited in shades. Too limited. Testor's makes every color you can think of, so I'm going to try it. Hey, only 2 things can happen. It'll work. Or it won't.
Nice taps, Jason, very nice taps.
Dale
Thanks Dale.
I intended to go to the store today to get some paint a few things got in the way so maybe I will be able to get there tomorrow.
I went and picked up some paint today. So far it has been great. Only need a little to get a nice solid color. Mixes very well. I did not notice and negative results within the resin. The resin did not seem to setup any quicker compared to PearlEx. Once it dries and I can turn it I will post a picture. Should have it turned in a few days. I used an orange paint and mixed it with the macro pearl PearlEx and it came out a nice sparkle orange color. Should make for a nice blank.
I will be going to buy more colors as this seems to be a pretty good option.
I have used Testors paint to color the tubes but I have done only 2 blanks with the paint in the PR. It didnt seem to affect the curing time.
Nice Taps......
Here are a few more taps I just finished up. You can also see that I keep a mold handy for stoppers and put any extra resin into so it doesn't go to waste and provides for a funky stopper blank.
Here is a picture of the molds I use for the taps as well. I think somebody asked about that in an earlier post.
