workinforwood
I've been reading for years about packing tape being a lubricant for scrolling. People take a stack of thin boards. They glue a pattern on top and then wrap the entire stack with packing tape, drill the starter holes and cut out the images or whatever. I just can't see how this can be possible. Packing tape is plastic and on top of that, it has glue on it. When I cut plastic with my tools, the plastic sticks to the blades and has to eventually be cleaned off. I never heard of a plastic that lubricates, and if the plastic is sticking to my tablesaw blade, that's the opposite in my mind for lubrication. They swear by the tape. I've heard some say it's because of a coating on top of the tape that helps it not stick to itself, but packing tape sticks to itself just fine last I tried some. Otherwise it would be sold as a rats nest, not a nice roll would it not? Others say that masking tape works just as good as packing tape. The main benefit seems to be a reduction in burn marks. I have my own theory. My theory is that the tape with plastic and or glue, leaves a residue on the blade. The residue prevents burning because it slows down the speed of the cut and maybe even lets some air squeek in between the blade and the wood. The reduced blade speed cause by drag will reduce the friction of speed. They say when the leave the taped area to a non tape area, the burning begins shortly after. I believe the residue on the blade has now left, causing the speed of the blade to increase along with the metal on wood direct contact and thus the burning. I rarely encounter burning, but I run my saw slow and I think most people go fast like they are in a race, but can't say for sure that's true. So...what's happening? Is it lubing, or is it the opposite effect which is also a positive effect.
