ok, up front I know nothing about this tool, but I do know a thing or two about jointers and planers. For starters both use a rotating drum with knives or square blades mounted parallel to the axis of rotation to remove a thin slice of material as it passes by them. The major difference is in the purpose the tool is designed to meet. A jointer is designed to produce a smooth flat face on a piece of wood regardless of what the other faces of the workpiece look like. IE, you can take an irregular chunk of wood, run one side of it over a jointer a time or two, and produce a flat, smooth face on one side. If you need or want too, you can use the adjustable fence on a jointer to produce a second smooth flat face on the workpiece at a specific, adacent, angle (usually 90 degrees) to the first one.
A planer is designed to produce a second flat, parallel face on the workpiece OPPOSITE (or directly opposed) to the first one. That's all it's designed to do. If you don't have a flat, true and smooth face on one side of the wood, a planer is probably not going to give you a second one, or therefore do what you want it to do.
The primary tenet of flat woodwork, is that you have to have one truly flat, even and true face to work from. The planer is the only tool that will give you that reference plane or surface to work from (for the most part). The limiting factor of how large a workpiece a jointer will give you that face on is the length of the infeed table. In general your jointer will produce that true flat surface on a workpiece that is twice the lenght of it's infeed table. That can be modified with extra work, or the use of infeed jigs or other aids, but that's the bottom line. You will only be able to easily flatten and true a piece of wood that is about twice the length of the infeed table of your jointer. Longer than that and you run the risk of just narrowing the workpiece while copying the warp, arc or twist you are trying to remove.
Just how usefull is this to somebody that is looking to produce 6 inch pen blanks? Not very, really, but if you are only looking to make pen blanks you really don't need a jointer and planer in the first place.
I hope this rather rambling explanation makes sense, and maybe even helps someone. If so please let me know.
I really gotta quit drinking mountain dew at midnight
