NEWS FLASH: On the Gatsby/Sierra I would be willing to bet that it is NOT the glue. Residual glue residue in the "tube" does will not affect operation of a Gatsby. The _only_ way glue could affect the Gatsby/Sierra is if someone deliberately placed glue INSIDE the receiver of the clip end, which has little to do the the tube. Or, someone were to put glue on the transmission end that fits into the clip. Please look at the kit and the way it is constructed.
The Gatsby/Sierra is getting the "glue residue blame" based on "association" with other pens that _do_ have this problem. The Gatsby/Sierra is not constructed or operate in the same manner.
On the Gatsby, the tube is inserted onto a thick machined part of the clip end that will _not_ distort from the tube, no matter how much glue is in the tube. Again - Residual glue residue in the "tube" does will not affect operation of a Gatsby.
I had the assembly problem last month. I still have the pen somewhere in my shop. Basically the transmission and the machined clip end do not match properly. The clip end hole seemed to be something (estimating here) like .05mm too small. I did not measure it at the time due to trying to get a pen finished. But I did try 2 or 3 other clips in it and it had the same problem. I tried the transmission in another end and it worked OK.
For me: The conclusion was that there is an occasional Sierra clip end that is miss-machined.
