tdibiasio
I am really getting tired of changing speeds on my Jet 1220 by changing the belts to pulley locations. I have been researching VS lathes as a replacement, however I would like to stay wilth the same general size of the 1220. I know that Jet makes a 1220 VS which would be perfect size wise, but it appears like you still have to change the belts locations to go through the range of spindle speeds. My questions are two:
Is there a fully VS lathe out there in the same general size as the Jet 1220 that would not require belt changes? (make and model)
Also if I went with the Jet 1220 vs is there a pulley setting, say the mid range, that would get me through most pen turning activites without having to change the belt? I usually turn the pen in 1800 range and sand and finish in the 800 range. I have tied to find online the vs speed ranges within a particular belt setting for the 1220 vs, however I was not able to find this - even by looking at the product manual.
I think if I could get by with a single belt setting within the VS range 800-1800 and then only have to change the belt to get into the 2000 range for polishing and buffing of the wax, I could live with that.
Any input would be greatly appreciated.
