TowMater
Finally got my shop space mostly cleaned up and organized thought you all might like a peek at my little shop, it's 20'X24' with a HVAC unit and Water heater sitting right in the middle that I didn't bother to photograph.
First up, my blank storage. Pen blanks and Bowl blanks. To the lower left you can just see where I store the bulk of my project wood (below the landing of the stairs going up).
Next up is the mini-lathe bench with grinder, it's not finished as I haven't installed all of the drawers and closed everything up but I've fairly happy with it.
To the left of that is the HF lathe I use for small bowls and buffing.
As you turn left from there there is a shelving unit that will come out in the coming days so I didn't bother to take pictures of that. This is where the tablesaw, and dust collector sit. I also have my clamps sitting there which I need to get organized soon. Just beyond that is the 8" jointer.
As you turn the next corner the stand I made for the bandsaw and drill press sit there. The bandsaw is apart as I have new bearings that need to be installed. Sitting next to the stand is a RBI Hawk scroll saw a friend of mine purchased without telling his wife and asked me to store it in my shop for him for "A couple of months max". That was about 18 months ago.........
Next to that is the staging area (Walnut is for a TV stand I'm working on). Under my plane storage you can see the benchtop material I'll be workin with and next to that is the Leigh D4 I got off of CL for $100.00.
Last but not least is cutoff storage, my crappy old Whiteside bench I had to bolt to the wall behind it so it wouldn't walk all over the shop. Above are a couple of storage lockers with miscellaneous finishing and fastening hardware and above that is some storage for some QSWO I picked up a while back.
Just to the left of the bench is a staging area for projects in progress such as bandsaw parts and an emmert vise I'll be putting on the bench.
So that's my shop such as it may be. Big shop projects for the year are the bench and a router table, both of which I have 95% of that stuff for already just need to get up the gumption to build them. Only refurb I plan on doing this year is the DeWalt MBF RAS I have sitting in the garage.
Thanks for any comments, and if you have any questions or would like a better pic of something just let me know.
Todd
Todd
