PHDesign Vise
sdemars
Louisiana, USA.
Since I am looking forward to receiving my PHDesign Vise someday soon . . . We are preparing a home for it. The wife and I are currently building a roll around turning tool cabinet.
If anyone already has a PHDesign Vise, I would appreciate some "footprint" & height dimensions so that I can design a storage spot into the future cabinet.
Steve
Don't bother,
Once I got mine set up is has not been off of the drill press table except for occasional "other projects" but was always within arms reach. It doesn't need a spot in a cabinet. Perhaps a pedestal but not a cabinet.:smile:
What you gonna do with a PH Vice in a cabinet? Just kidding, others have already said it but my bet is it's home will be on your drill press. I don't have one myself or I would give you the info you are looking for.
I have mine mounted on a wooden base which has a hole drilled in one corner. I hang it on a nail when it's not on the drill press table.
I do the same thing Jeff! Steve, you'll need to make some kind of base for it to keep from hitting your knuckles when operating it so I would wait until I had my base made. I'll get out to the shop later and take a photo and give you the dimensions of mine but your DP might be different.
OK, here's some pics..........
The dimensions of the vise only are 3" high X 10 3/4" wide X 2 3/8" deep. The block of wood I have it on is 2" high and gives me knuckle clearance. The last picture just shows how I store it when not in use.
Thank you very much . . . I can't wait till we get ours . . . .
This definitely gives us ideas for storage & makes us start thinking of a method of positioning and securing to the DP table when in use . . . . My drill press is a DELTA 70-200 (20' WITH 4 3/4" depth) with a fairly large table. While probably to big for pen making & not the optimum choice for wood working, I am hoping to find a way to to utilize the "T" slots built into the DP table. I'm sure someone makes the special bolts to grab the slots . . .
I mounted mine on a piece of 1"x4"x8" oak and put a magnetic holddown on it, but like most others it hasn't left my drill press for more than a few minutes at a time.
Any chance . . .
Any chance you have a picture of yours . . . The magnetic hold down seems interesting . . .
Steve
Hello Jeff . . .
Just curious if you could re-post the picture and dimensions of your PHDesign vise. I had assumed it would be there so I did not copy the info. I sent you a PM about same.
Well, I guess it was not "Jeff the Administrator" that posted the PHDesign picture with dimensions for me . . . . If anyone has dimensions to a current production PHDesign vise I would sure appreciate it . . .
Need footprint, height, width, depth . . . heck anything . . .
I'm designing a platform for the vise "into" my drill press table that will allow me to raise and lower the vise while keeping it center to the press. I currently have one of the Rockler Vises with the little drawer. I think it is about the same size as the PHDesign vise. If it is about the same size that would be sweet. If not I will design to accommodate both . .
Thanks in advance,
Steve
