Joe, by Huts, I assume you mean their PPP bar.  If so, drill a small hole in the bar near one end and hang it from the wall where it is out of your reach. :wink:
Seriously, I would not use it at all.  As far as sanding, what grit you start with depends on how smooth a surface your turning tool leaves.  Sharp tools and a light touch improves the surface.  I generally start with 320 grit, and others start much higher.  Remember to sand lenghtwise with the lathe off between grits.  Blow the dust off the blank between grits.  I generally switch to MM after 400 or 600 grit.  Run through all of the grits of MM so that the unfinished blank is shiny.
Then, read some of the tutorials on CA finishing and practice, practice practice.
I hope this helps,
