I use the foam sheets that come wrapped around the electronics... cut them into strips about 1 x 3 in... the Ca doesn't stick to them and if you are careful, you don't get any on your fingers.
I tried the glove routine, always wound up glueing the fingers together or to the blank or to the paper towel, then wound up with a hole in the glove, so glue on the finger, inside the glove.... tried the little bags, but always have trouble opening them, so most of the time I just tear the tops off... can use them then... when I did use them as finger tips, I couldn't feel what I was doing to my liking...
