texasfootball21
I need some advice on how to get a high gloss finish on antler. After doing some reading, here's my plan:
1)Get the pen to the correct profile filling the pen in with thin CA glue as I go, then sand to about 600 grit.
2)Coat the pen in thick CA glue (never used a glue finish before).
3)Scrape off all the excess glue.
4)Sand from 150 grit to 12000 grit.
5)Use spray lacquer(never done this before).
6)Use Renaissance wax on finished pen, metal and antler (never done this before).
On step 4, do you wet or dry sand? And with the lathe on or off(lathe speed?)?
Will this achieve a polished marble-like finish? If you couldn't tell by all the "(never done this before)" I don't know what I'm doing. I know I need to experiment but I do need to know what I should order to finish the pens. Any advice would help and is welcomed.
Thanks.
Thanks.
