Dan_F
In another thread, George said he has this lathe, but hasn't had a chance to use it much. Just wondering if anyone else out there has it and could give a brief review. Thanks,
Dan
Dan
Dan
Dan
My shop is in the basement, or I would probably just go for the Grizz 12 X 36, but at over 1000 pounds, I can't see getting it down the stairs. The G 4000 has a single quick change gear box, whereas the 4003 has 2, and most of the other small, non-9 x 20's require manual gear changes. I don't really know much about them, but got a little advice from a fellow turner yesterday who has a 12 x 36.
Dan
Dan, I recently purchased one of these and posted about it here.
My version of the 9x20 is an electronic variable speed with a 750W motor, it also has a camlock on the tailstock. Both these features are worth their weight in gold.
I don't know whether this version of the 9x20 is available in the US, but I would assume it would be.
I am also working on a toolrest set up so that I can use it as a pen lathe if I want.
The toolpost and rest is fairly easy. Remove the compound. Take 1" square steel tube about 7+" long and drill for your favorite tool rest post. The post will go inside the bed ways. Add a threaded hole to fasten the tool post. Drill 5mm holes to match the cross-slide. Install 5 x .8 mm 30mm(?) make or buy some t-nuts for the slots. Done. I'll take a photo later and post it in the thread. Time for supper now.
This is not true with the Grizzly G4000 which is being discussed here. So as not to confuse anyone, the Grizzly G4000 also has inch increments on the dials. If I want to take a .020" deep cut, I simply turn the handwheel .020"!I ended up getting the MicroMark version of this lathe, largely because the handwheels turned 0.050" per 360 degree turn. Most others (at least a few years ago) turned the metic equivalent, so it was difficult to do precise US measuring without calculating metirc to US. This might not matter at all for penturning, though!
