woody350ep
Alright. I have a dilemma. I have been working on modifying my CA/BLO finish to make it faster and more effective since I started having some troubles with spotty finish. I got with Brandon25 about some things and got a much faster (in my hands) finish, and a much for even one. I am STILL having a problem with my PlastX now though. I was sanding to 650 pre CA, then CA/BLO, then MM to 12000 and PlastX. Well, the PlastX actually took the MM BACK toward the dull/hazy look instead of amplifying sheen. So, I thought maybe it was my pre CA sanding, and I tried a couple today that I went all the way to 12000MM, then CA/BLO, then MM again to 12000 and PlastX.
Same thing.
It's like the PlastX wants to shine up, I can see it when I apply it and work it in. It shines up nice briefly, and then if I take a clean part of PT to wipe off, it goes to dull and hazy. It does it without wiping it off also, hazy that is.
No more spotty finish like I was having before, its ALL hazed. Am I doing something wrong with this PlastX? I apply it at 1500rpm with PT (Viva) and work it back and forth with some pressure for about 20 seconds, then TRY to wipe it off with a clean part of the PT.
Can I just leave the pen at the MM stage instead of trying to add the polish to it? Or, will it show some bad signs down the road, such as dulling down, or affecting the finish? I don't see why it would, but I would like to know what's going on here. I am hoping I am now doing this PlastX wrong and there is a simple solution.
Do you guys work the plastX into the pen while applying, or do you apply almost no pressure and just get the stuff on it and let it do its thing before wiping off?
One last thing. I am absolutely positive I am not sanding through my finish now. I took precautions of 12 coats of beautiful CA finish on my last pen today and started final sanding at 1800MM-12000, thus removing almost nothing from finish.
PLEASE PLEASE someone help me figure this out, I am getting desperate.
P.S. Sorry for the length, but its too late for that now lol
			Same thing.
