nwcatman
i am considering an outboard tool rest setup for my old rockwell/delta lathe (pic in album) and would appreciate any plans/thoughts/ideas/advice you experts have on the matter.  thanks
			got a pic by any chance? i am thinking about filling a 5 gallon bucket w/cement with a big pipe coming out of it.I used a 150 lb.-- 6 x6-- heavy wall square steel tubing with a 12 inch sq base that is 2 inchs thick.
Works great and doesn't move around.
Don't forget that the outboard thread on your spindle will probably be a reverse thread so you will need a special faceplate and your scroll chucks won't fit.
I will post a pic for you later today.---Most of the home made ones I have seen----use a old tire rim for a base.
i have a grinding wheel/wire wheel set up on a tire rim but it rocks a little so i don't think it would be a good thing for a toolrest.I will post a pic for you later today.---Most of the home made ones I have seen----use a old tire rim for a base.
there was no linkThere were plans for building your own .... and anchoring it to your lathe .... in an older issue of WD. We talked about this a while back. Let me check the archives.
Here it is ...... http://www.penturners.org/forum/showthread.php?t=34090&highlight=outboard
WD Winter, 2008
Heck I just run the lathe in reverse---they also make left handed treads.
Don't give up so fast.
i hope ur JET freezes up this winter.This is when the Jet 1642 and mustard monster owners smirk. I just run the head to the other end of the lathe, move the chip can and start turning..
Machines that run don't freeze--they just cool off until they are needed.
They aren't like key boards
Randy,
I'm being a little dense right now, so you'll have to explain this.... The headstock on my lathe rotates outboard and turns the same way outboard as it does over the ways... I just have to step left a little and move the tool rest to the left side of the headstock, otherwise, nothing has changed...... what am I missing??
exactly. and i can switch to the other side of the headstock, but the shaft has a left hand thread on that end. i guess i could rig up a fan to run on that end since its always hot here.Most headstocks don't rotate. Or slide to the other end of their bed either. For those lathes the only choice is to switch to the other side of the headstock.... Or buy another lathe.
Marc
you are RIGHT! back to the drawing board i guess. dam.
I think I mentioned this earlier, perhaps without enough emphasis. If you have one of the standard spindle threadings, it should not be difficult to find a faceplate with reverse threads.
Try looking in the Grizzly catalog or do a simple general Internet search and you should be able to find one.
