Protecting lathe while wet sanding
randyrls
Harrisburg, PA 17112
When wet sanding acrylics and CA, I have a piece of heavy black shelf liner I got from Harbor Freight. I originally got this for my tool box, but had an extra piece.
16" x 22" TOOL BOX LINER ITEM 90982-4VGA $2.49
This works very well to keep water off the lathe. It is heavy enough to stay down, and stiff enough to stay in place.
Hope this helps!
Randy, I use a wetting solution made with Cool-Tool from Raytech, It's used on Diamond coated tools which would rust with plain water, I don't have to cover any thing, 8.00 gives you about 3 gallons put that in a coke bottle with a very small hole in nit and you have a red neck squirt bottle,that just drip a little drop when you want it.
I just use a shop towel laid and the bed to protect it. The bed has a good coat of wax on it also. Every couple of week depending on how much I use it, I give it a good cleaning and waxing.
I just lay an old wash cloth or a towel under the blank on the lathe bed, then set a cool whip container with my sand paper and water on top of that and most of the water drips back into the container.
I use paper towels which work great, but the shop towel is a good idea too. Anything to keep water off the bed!
I use a tall kitchen plastic bag. Slice it so it opens flat, lays across lathe bed and table. Water rolls to floor. I use it for C/A as well as wet sanding. Use it over and over again, couple months at least. Carl
