onewaywood
Does anyone know of a accelerator replacement I'm in a bind and need it in a hurry I'd rather not go to my local Woodcraft.
			If you are using it for the finish then do not use the smoke as it tends to give a cloudy finish.
Actually Skye, nail polish remover works as a solvent or debonder for CA.You can try your wife's nail polish remover if it's a mixture of %5 perfume and 95% acetone. I've heard it works just like accelerator.
Accelerators: Speed the cure of cyanoacrylates and cure any liquid adhesive outside of the joint.
Primers: Using primers on hard to bond plastics, will increase the bond strength.
Debonder: Use to remove cured cyanoacrylate adhesive.
Product: Aerosol Acetone Accelerator (10 oz)
Base: Acetone
Unknown: color: Clear
Viscosity (cps): 3
Application: All Cyanoacrylates
Product: Debonder
Base: Nitromethane
Unknown: color: Clear/amber
Viscosity (cps): 3
Application: Adhesive Remover
