Has anyone done these?
I will be making a few religious pens this winter and seen this new one from PSI. Has anyone done this one or any of the others in that series? Question regarding this kit what is you opinion of the kit? Is it a quality kit? How well does the refill mechanism work? I see they are out of stock as well as this blank that matches well with it. Final question, can that top of the finial be replaced with a casted piece? Or is it attacked to the cap portion and can not be popped off. Thanks.
Is anyone else selling this kits that you know of.?
I just did one today that's very similar. The blank turns nicely - squared up pretty quickly, and it's a softer resin that isn't prone to chipping. I finished it with the 9-step micromesh pads and One Step plastic polish. The kit itself feels solid and went together well. My only criticism was the cap that pushes on over the twist mechanism - it's supposed to go on by hand, but it was really stiff getting on. Otherwise it was a breeze. Once it was together, it ejects and retracts the refill very smoothly.
On the one I did, the top of the cap can't be removed. I can't say for sure if that's the case with the one you're looking at.
Thank you. That is in that series so I am guessing they are all the same except the theme. I may get a couple to give it a try when they come back in stock. Resin was probably alumilite.
