Anyone tried the PSI knife yet?
BHuij
Utah
I got the PSI Christmas catalog in the mail today and noticed that they have a knife. It appears to be based on a 7mm brass tube for the handle, and screw into the blade and pommel.
While I appreciate the simplicity of turning and assembly, I worry that a friction fit screw in a 7mm brass tube is a fairly weak point of failure. Anyone played with this kit yet? The blade looks to be of decent steel and a useful shape for what I'd probably want to do with it (general purpose camping knife). I'm intrigued.
No experience with this, I didn't even know it existed. I collect pocket knives, so this kit is a no-brainer.
As for your concerns about the assembly with screws, I'd suggest using a thread lock, like Loctite. Hopefully you'll never need to disassemble it!
Less worried about it coming unscrewed than just breaking because 7mm brass tube is not very strong.
Still I'll probably give it a shot. Worst case I don't like it much and it can be gifted to someone who will appreciate it, or relegated to some kind of light duty role.
I don't think it's intended for heavy use. I for sure wouldn't even think of batoning it or hard bushcrafting and if anything would only use it for opening packages and cutting up light cardboard. That 5Cr15MoV steel should be serviceable for light duty, but more than likely it will mostly be a display piece. The most fun will be coming up with crazy ideas for mixing materials for the handle.
We have some of the 7mm hobby knives from woodturnigz and I haven't had any trouble. They are not used for heavy duty cuts as the blade is thin. I used epoxy for the tube glue-ins.
Liking them so far for use in the shop.
The hobby knife kits, are based on a 7mm tube. But they are fitted with ann x-acto blade, and are only intended for light hobby use.
If you're talking about this one.
It is turned like a pen kit, but is based on a 21/64" tube and uses bushings on a regular mandrels.
It utilizes a integrated through tang for strength.
Would be an easy turning gift.
I looked at the knife on the back page of the catalogue. $15.95 tells me that it's not a quality piece of cutlery. I have a couple of knives that cost many times that price. The PSI knife will cut but go dull very quickly. JMHO.
Yeah, but it will sharpen easily, and it's highly corrosion resistant. As I said earlier, I think it's more of a show piece than a user. Cool idea, though. I just ordered a couple just for the halibut.
