Ambrosia Maple and Ebony
See more from Alan Morrison
Alan Morrison
N Ireland
With brass accents on an Etesia from Beaufort Ink.
Looks like a lot of work went into this very nice pen! I am curious how this small detail is built?
Looks like a lot of work went into this very nice pen! I am curious how this small detail is built?View attachment 395435
All parts are drilled before assembling onto the tube. I cut a section of ebony and a similar sized piece of Maple. The maple is sandwiched with two brass rings.
I hope that I explained that clearly......it's been a long day!!!
Alan
So do you turn these just like any other blank? They don't tear up the tool?
Do you stack the brass cut outs to make wider rings?
Brass is fairly soft for turning, so no issues on the lathe or with tools.
The rings were cut out of the sheet using a jewellers punch, though they can be drilled out to suit the tube and ringed on a scroll saw or cut with snips.
ok.
I did find an older post about accent rings where aluminum cans are used or thinner brass sheet material. I believe someone was talking about epoxying the cutouts together for a wider band. How would you not see the gap when finished? Maybe a dumb question but I am trying to understand. The accents look nice.
ok.
I don't think that you could disguise the fact that two pieces of aluminium were glued together.
Honestly, I used aluminium from a drinks can once about 10 years ago, and thought that it just wasnt worth all the cleaning required. The colour can show through, and because of its thinness, it is difficult to sand the surface to put a key on it.
I think that the brass sheet that I used may be more than 0.05mm .....I will check next time.
BTW you dont learn too much without asking....so ask away.
