George883
I'm trying to identify the wood on the pen to the right, lower half.
The design of these segmented blanks is outstanding. Makes me want to try mixing more TrueStone with brass and exotic woods.It looks a lot like the Sonoran desert ironwood that I have made pens from. It has the kind of chatoyance that I see in your pen. Here are a few examples of some of the pens I have made using it. - Dave
Sorry, I really didn't intend on stealing this thread. The segmenting was very simple, just diagonal slices. I scuffed the metal really good before gluing and I glued with epoxy letting it cure a couple of days before drilling. I use 90-degree point angle drill bits that are usually used for soft plastics, hard acrylics, and thin sheet metals to help prevent cracking or shearing when the bit penetrates the different material layers. - DaveThe design of these segmented blanks is outstanding. Makes me want to try mixing more TrueStone with brass and exotic woods.
Have no hesitation of adding photos and context! It is appreciated and gives inspiration for as you said - simple segmentation; that looks superb. Your few words of process is concise and complete. Often simple is better than complex. Be well!Sorry, I really didn't intend on stealing this thread. The segmenting was very simple, just diagonal slices. I scuffed the metal really good before gluing and I glued with epoxy letting it cure a couple of days before drilling. I use 90-degree point angle drill bits that are usually used for soft plastics, hard acrylics, and thin sheet metals to help prevent cracking or shearing when the bit penetrates the different material layers. - Dave
