Penn State turning between centers live center
Monty
Group Buy Coordinator
Pearland, Texas, USA.
All of a sudden, I am having the spanner nut that holds the bearing in the live center work loose. I've tightened it down as tight as I can, but it'll come loose again before I finish turning one blank any suggestions on keeping it tight?
Don't want to put Loctite on it in case I do need to replace the bearing.
As has been said already, blue Loctite is designed to be removable with normal hand tools (at about 50 to 60 foot-pounds of torque. If it is stubborn though, you can heat it with a heat gun to around 300 to 350 degrees F which will soften the acrylic resin in it so that it can be removed easier. - Dave
