Carbide cutter sharpening
CMC75
Indiana
First off, today I found one of Mark's videos on turning and learned how to use the square cutter differently than I am using it now. Mark your videos are great for new turners like me, so thank you!
Secondly, I realize the cutter blades will last a while and you can also rotate them along the way but how often would you say you would sharpen a blade? Should I look into a diamond card sharpener for keeping the blades in good cutting shape? Thanks
I sharpened mine for a while but it didn't seem like they were quite as sharp as new ones. It's possible that may have been the guy doing the sharpening too. The video @Mortalis shared is a great example of how to sharpen the cutters.
Anymore, I will sharpen my cutters occasionally but usually just order a new cutter head. It gives me an excuse to get some M&M's from Exotic Blanks.
I do not personally know anyone who sharpens the negative rake cutters though.
Mark Dreyer feels that rubbing the carbide on a fine surface only burnishes it. May get a couple extra hours from it. Recommends buying new carbide cutters.
Good idea, bugradx2. M&Ms are made here. Support the local economy.
Resharpening is purely dependent on how much wear there is. I look at mine through a B&L microscope and I've seen the wear start to erode the relieved side. When that happens you're better off just replacing it.
I have honed my carbide bits for many years. Always sharp.
This will not work the negative take bits. As soon as you think. "Is this still cutting like new?" Hone it. Remove the bit from the tool. With a diamond credit card hone, put a drop of water on the hone. Place the bit face down in the water drop. Move it in a figure 8 pattern 8 times around the 8. Rotate the bit 90 degrees and repeat 3 more times. Dry the bit AND the HONE. Takes maybe 3 minutes.
I sharpen my regular wood lathe tools with diamond hones, but have stayed away from sharpening any of my carbide barrel trimmers for fear of not getting each one to the exact same height which I would assume is not going to work out well. How do you sharpen and keep each blade the same width?
Haven't crossed that bridge yet. Just my carbide tools about a month ago.
