Pen Wizard Fordum Adapter ???
Bob Roehrig
Venice, Florida
Hello all, I may have finally found a lead on obtaining a used Pen Wizard machine. In case this works out, I'd like to know if anyone out there has the Beall Fordum tool adapter for their machine that I may get some measurements and pictures to make myself one. If my machine comes through, I want to be able to use 1/4" router bits with it and the Fordum would be my answer. Thanks in advance.....hope someone has one.
I used a Foredom 44T (if I recall) and don't recall having an adapter. But, I've slept since then.
You might see if you can contact Ed Davidson. He did more with the pen wizard than anyone else I recall.
Yoyospin.com
Hi.....very interesting. If you did use the 44T handpiece, how did you secure onto the Pen Wizard to make it work? I'm thinking about just making one out of wood and securing it to the machine but I have no idea what it even looks like. Was hoping someone out there could send me a few closeup pictures of there's. I can make anything if I can see a picture of it. Your the only response I've receieved and I'm starting to believe there are not many Pen Wizard users left among us. Thanks for getting back to me on this.
Hi Bob,
This may be the item you are looking for. The tube looks like it is made from delrin or similar plastic material. The OD is 1 5/8" and the ID is 1 1/64" and the length is 2 ". The hole for the black anchor bolt is 3/4" from the closest end. The three holes on the top line up with the three holes on the tool holder on the Pen Wizard. I hope this helps. Let me know if you have any other questions or need any other measurements. I bought mine a while back and have just started experimenting with it during the last few months. There seem to be a lot of possibilities.
Tim
Hi Bob,
Tim
Thanks so much.......THAT'S IT !!! That's easy to turn on the lathe and should work perfectly. Was mentioning earlier that I finally after 3 months of looking located what looked to be a nice Pen Wizard on Facebook Marketplace in Edmonton Canada. Yesterday as I was about to finalize the deal and send the money I was alerted this was a Scam by Meta Facebook. So now I'm back to square one once again looking for another Pen Wizard to purchase. So close, but so far away. Oh well, least I didn't loose hundreds of dollars and thank goodness I was alerted. Thanks for the pictures.....soon as I ever locate another Pen Wizard I'm hoping to build this. Really appreciate your sending this.
