Curious about your firsthand experience here. I also turn between centers, but with bushings. So I don't necessarily have bushings for every pen I turn, but as long as I can find bushings that properly fit the inner diameter of the brass tube, I can mount the blank between centers and turn down to the correct diameter for the pen hardware just using calipers. Then I swap over to a mandrel w/ delrin nonstick bushings and a mandrel saver to do sanding and CA finish.
I've heard of people doing TBC without any bushings at all - a 60° dead center directly into the brass tube in the blank, and 60° live cone center in the tailstock side, again directly mating with the brass tube. Every time I've tried this, I flared out the brass tube to the point that it was no longer a good friction/press fit with the rest of the pen hardware. When I tried to avoid this by backing off tailstock pressure, I couldn't get enough hold to properly turn the blank. I can't seem to find the happy medium. What's your secret?
Edit: to OP, I started off with a pretty standard fishing-style tacklebox to store and organize my bushings. Ultimately I switched over to a custom 3D-printed TPU style of bushing storage that is very compact and hangs directly on my pegboard, so it's really accessible. I posted about it
here.
