Robert Sherlock
I have some special pen kits available - The Berea Tropical Series Baron Pens that come (included!) with either white coconut, brown coconut, or green abalone cast resin blanks. I will update this list as items are sold.
These pens are clear resin casts that Berea sold a few years back. THESE DO NOT USE NORMAL BARON BUSHINGS. I do not have the bushings available. You can turn these between centers if you use digital calipers. You must use caution turning these; like anything done in clear resin, they can be brittle. I believe the tubes in these kits are the same as regular Barons, but the final material thickness is much thicker. Thus if you have regular Baron bushings, you should be able to make them work. I am not positive however.
- Respond in this thread the kit(s) and quantity you would like. I will message you with your total and PayPal information.
- Shipping will be via USPS Flat Rate boxes at buyers expense.
- I will combine shipping if you order from my other post here: https://www.penturners.org/threads/pen-kits-for-sale.186177
- 1X Baron Fountain Titanium Gold - White Coconut: $10 each
- 2X Baron Fountain Platinum - Green Abalone: $15 each
- Baron Rollerball Titanium Gold - Brown Coconut: $10
- Baron Rollerball Titanium Gold - White Coconut: $10
