How deep does this stain go in this walnut slab?
Lexington, Ky
I'm surfacing this 2" walnut slab on the CNC, and I'm wondering what this dark coloring is on the lighter sap wood and how deep it goes? I don't have a lot of experience with walnut, and I haven't seen this kind of coloring in other peoples' projects, so I don't know what to think.
Will this unwanted dark color possibly lessen as I take more layers off?
Turn the board over and see if it is on the opposite side. Probably is. All part of the sap wood in that tree.
The gray streaks are moisture related oxidation and fungal reaction. Usually this is seen in the white sapwood. If you want to see it even more pronounced, go cut a large holly limb (or tree) in the late spring and cut it into a board. Within a couple of weeks, the white holly will be gray from the excess sap in a fungal reaction. In some cases it affects the spalting in different woods.
The reason you see it in the white wood of the walnut is that there is more moisture traveling in the white sap wood than the brown and (I have been told by several over the years) - wood cut in the spring and early summer will be more likely to have spalting or graying in the sap wood because more moisture is traveling through it at that time. Again, I have been told that if I want white holly to stay white, cut the tree in the late fall or winter. I don't know how true that is but I have heard it more than once.
BTW, the graying of the sap wood can be found by Googling: "Why is the white sap wood turning gray?" But, I learned it the hard way by cutting a neighbor's small holly tree in the early summer (at his request) and seeing the white holly turn gray within a couple of weeks, destroying its value to me!
Thanks for all the info guys. It's on the reverse side as well so it goes all the way through. Even gets more intense as I've taken off more layers.
The place where I got this only has rough sawn wood so I wasn't able to get an idea of it's coloration before shelling out the dough. Is there any kind of quick field cleanup of the surface I can do in the future to try to avoid getting this kind of coloration?
I use walnut slabs all the time and see this a great deal. Is your design planning to use or not use the lighter colored sap wood? If you don't want it then just cut it off.
If you're going for a live edge and want to show the transition from darker wood in the center to light on the outside of the tree then just leave it. That's what the tree is. I've never had anyone question that coloration shift.
I've gone back and forth with the plan. Originally, I only wanted the darker hart wood; but when I got it home and saw I had the sap I thought about integrating it in. So now I see this dark color I'm reconsidering only going with the hart again. Still some time before getting this in the CNC for the final design so I guess we'll see.
. . . Is there any kind of quick field cleanup of the surface I can do in the future to try to avoid getting this kind of coloration?
There is no"field cleanup", as that stain is in the wood from the sap that has soured in the wood. The only way to get a clear cut is by finding custom logger or sawmill, get to know the owner manager and wait for the right log/lumber to come in at the right time. A (high priced at that) custom logger/sawmill will know when and from where to get those type of logs/lumber.
Thanks for the advice about getting to know the mill owner. I was actually referring to cleaning up the rough-sawn edge a little so I can see what color it reveals. After permission is granted, I think a hand plane and mineral spirits is about as good as it gets.
