Tubes and Mandrels
Angusga
Hoytsville, UT
I like to use the mandrel saver in conjunction with the threaded shafts as I can tighten the blanks onto the mandrel with the lock nut and then use lighter pressure on my tailstock without having the blanks catching as easily. I'm ordering a mandrel today that adjusts length through a collet at the headstock. I'm going to make a mandrel saver that will thread onto the shaft with a 60 deg. end to receive a tailstock live center to help with concentricity while also bolstering the mandrel at the tailstock end. I may also make a mandrel saver that can attach to my One Way live center with a better fit over the threads on a mandrel. The fit of the 7mm pen tubes on these mandrels is less than ideal causing vibration and chatter especially on two piece blanks. I wish the mandrels were slightly bigger in their diameter. This is only problematic with the smallest 7mm pen tubes when turning a two piece blank. With a one piece blank I use shop made between center bushings.
I've made end and center bushing sets to use between centers with two piece blanks but get quite a bit of vibration with them and have to use excessive tailstock pressure. It does work but requires more sanding to remove the chatter and bring the blanks to concentricity than I'd like. It would be nice if the tool manufacturers addressed these issues more precisely.
What have some of you folks done to increase accuracy and concentricity?
I turn between centres and stopped using mandrels altogether. I do use bushings between centres that have a 60 degrees
opening for both dead/live centres and this method has improved the concentric issues that I used to have. When I used
to use mandrels to make 7mm pens(tubes), I would turn only one(1) blank at a time and never two(2) on the mandrel to minimize the flex and increase the accuracy.
I have a collet based mandrel "driver" on the headstock side and a collet based mandrel "saver" on the tailstock side. The collets clamp down when I tighten the tailstock providing a "perfectly" centered mandrel on both ends (well as "perfectly" as the tolerances in everything permit. Unfortunately the company that made mine stopped a few years ago along with a bunch of other companies that made similar, collet based systems. As of right now, it's hard to find anything even remotely similar.
I think if I didn't already have a "precision, collet based system" I would probably buy a PSI Morse Taper Maxi-Mandrel or maybe a Morse Taper Keyless Pen Mandrel System for the headstock side since they use a collet for holding (and centering) the mandrel. For the tailstock I would go with a PSI Live Tailstock Chuck Adapter and a PSI Collet Chucking System, which comes with a 1/4-inch ER32 Collet. This would put a collet based live center on the tailstock side. For the mandrel itself, I use a Letter "C" or Letter "D" drill rod, typically M2 tool steel because it is less expensive and is very hard. I get them at McMaster-Carr. The diameters are very tight tolerance, 0.242 +0.0 /- 0.0002 for "C" and 0.246 +0.0 / -0.0002 for "D".
I almost always use the "D" as it provides the best fit for most of my bushings, but sometimes I will get a set of bushings that are a little too tight for "D", then I drop back to "C". Almost always this has been with standard, PSI "Slimline" tubes and bushings. (Originally the mandrel sizes were established by Berea and were set at 0.247 +/- 0.002 more like a "D" drill rod, but PSI specifies theirs at 0.243 +/- 0.001 - more like a "C" drill rod).
It would involve a lot, but it would provide tight tolerance, easily adjustable mandrel lengths (no spacers required), and collet based clamping and centering.
Dave
Dave
I use er16 collets in MT2 er collet chucks for a lot of different setups. They are the same thing that is sold as a pass through or adjustable headstock mandrel system. I hadn't thought of using one in a live center. I do have a live center drill chuck which might work just as well. and I use it for similar setups with my metal lathe. You've got me thinking now... That would do away with overstressing the tailstock pressure completely using just enough to stabilize the setup. The drill rod is a great idea. I'm ordering some tight tolerance stainless and carbon steel rod from McMaster-Carr today that is in that same range along with some 7mm tubing that they have. I believe it will give me what I'm looking for. I'll look at their drill rod for a comparison first though. er32 collets are on the big size for this but still smaller than my 1/2" drill chuck.
I use mt taper blanks made for turning jacob chuck arbors to make centers of varying angles and threaded arbors. I'm thinking that it should be possible to fit an er16 chuck onto my One Way live center system. Good stuff, Dave. Thanks!
When I started using the TBC method, it was for the purpose of applying finish without bushings - to avoid the popping off the bushing glued to the blank and to prevent the problem it caused with the CA lifting on oily blanks like ebonies, - BUT I discovered the much more precise concentric and smooth turning. Without bushings for finishing, and with bushings between centers when taking it to size. My calipers at that time only went to .005" and I got that much precision every time. It was about 10 years ago that I purchased a set of calipers that went to .0005.
Gordon: "I've made end and center bushing sets to use between centers with two piece blanks but get quite a bit of vibration with them and have to use excessive tailstock pressure."
Since I have always focused on the precision side, working with TWO pieces simultaneously has not entered my mind. If you want to do both simultaneously, you will either need to invent a new method or resign yourself to turning a two piece pen one piece at a time. There have been several people over the past 15 years who have tried to use a two piece in a true TBC configuration and have not yet made it work. I "THINK" there are a couple of variations of the TBC that uses sliding mandrel that accomplish that, but I am not totally sure.
I use the original TBC method that uses/turns one blank at a time.
Dave
Once again, Dave, thanks for your post. I just ordered some tool steel c and d rods. I've also found a threaded collet chuck that I can put a reducer in that will then go onto my one way live center. I've tried my live center drill chuck and it works quite well actually. I use a mt2 ER 16 collet chuck in the headstock. I like turning over the mandrel, so really hope the new rods will be snug enough to dampen the vibration effectively. The rods are annealed so I can thread one end to use a lock nut to provide the holding pressure. I can make my own between center mandrels so if I don't like this new mandrel setup I may just end up turning two piece barrels one at a time. Thanks again.
Thanks for your reply. I believe you are correct about the TBC approach. I turn a lot of small beads and texture lines on my pens and the leather tools that I manufacturer, so it's very helpful if I can see both halves while turning to keep spacing consistent I've played a bit with a center mandrel/bushing with mixed results. I think the mandrel ends need to be long enough to pretty much fill the tubes and they need a good snug fit. I'm suspicious though that the chatter vibration is coming more from the length of the setup and the multiple pieces than the mandrel fit. The chatter is worst at the tailstock end. I've had live centers that squeal no matter what. I turn tiny finials with no tailstock support too. It seems that this small items don't have enough mass of their own to absorb any vibration effectively. Right?
I found these er collet live centers on Ebay. https://www.ebay.com/itm/156472739780
