Havana ballpoint tubes
Don - do you know the dimensions? I have quite a variety of long tubes (can't remember if they are 8" or 10") that I'll gladly share if they fit, just need to know the diameter and the length per tube so I can check if I have the right ones, and work out how many you'd get from each long tube.
I'll check tomorrow when I'm in my shop.
Don -
Sorry, I can only match one of those two tubes. The lower/body tube appears to be the same as the "full size gentleman" lower barrel, but I can't find anything in my stock that matches the larger diameter tube.
