Ca Glues Preferred by IAP Members (Poll)
Vote for your preferred CA Glues available.
  • 3M Scotch-Weld
    Votes: 0 0.0%
  • Aerotech
    Votes: 0 0.0%
  • AG Adhesive Guru
    Votes: 0 0.0%
  • AK Crystal Magic
    Votes: 0 0.0%
  • Big Jeff
    Votes: 0 0.0%
  • BondXtra
    Votes: 0 0.0%
  • Burbank
    Votes: 0 0.0%
  • CamaLeao
    Votes: 0 0.0%
  • Chem-Set
    Votes: 0 0.0%
  • Cue Components
    Votes: 0 0.0%
  • CyaFixed
    Votes: 0 0.0%
  • CyaPro
    Votes: 0 0.0%
  • Dap
    Votes: 0 0.0%
  • Devine Dental Lab
    Votes: 0 0.0%
  • Duro
    Votes: 0 0.0%
  • FGH 1200
    Votes: 0 0.0%
  • Fix & Fusion
    Votes: 0 0.0%
  • Glue Angel
    Votes: 0 0.0%
  • Glue Masters
    Votes: 0 0.0%
  • Green Stuff World
    Votes: 0 0.0%
  • Grizzly
    Votes: 0 0.0%
  • Inoteca InstaBond
    Votes: 0 0.0%
  • Ivorie
    Votes: 0 0.0%
  • IxirPro
    Votes: 0 0.0%
  • Klingbond
    Votes: 0 0.0%
  • Kraken
    Votes: 0 0.0%
  • Maker Material Supply
    Votes: 0 0.0%
  • Mitreapel
    Votes: 0 0.0%
  • Professional Grade
    Votes: 0 0.0%
  • Rhino
    Votes: 0 0.0%
  • Stanley
    Votes: 0 0.0%
  • Stew Mac
    Votes: 0 0.0%
  • Totalbond
    Votes: 0 0.0%
  • UV Light Curing
    Votes: 0 0.0%
  • Y'All Can Diy
    Votes: 0 0.0%
  • ZP 40
    Votes: 0 0.0%
  • Total voters
    91
Wayne
IAP Library Manager
Staff member
Troy, Wisconsin, USA.
NOTICE: IF YOU ADD OR CHANGE A VOTE YOU MUST RE-ENTER ALL PREVIOUS VOTES!
Many members ask the simple question, Which CA Glue do members prefer to use? What do you use?
Here are some Considerations when choosing.
  • Always used one Brand
  • Bond Strength
  • Bonds Metal to Metal
  • Bonds Metal to Plastic
  • Bonds Wood to Metal
  • Bonds Wood to Plastic
  • Bonds Wood to Wood
  • Branded Accelerator
  • Chosen Odorless
  • Colored Dye can be added
  • Colors Available
  • Color Transparent
  • Container Micro Extension Tips
  • Container Seal
  • Container Sizes
  • Cost per Once
  • Drop Resistant
  • Ease of Application
  • Failure Rate
  • Filling Voids
  • Finishing
  • Finish Cracking
  • Flexible
  • Impact Resistance
  • Local or Online Availability
  • Matching Accelerator
  • Product Refrigerated Life (Unopened)
  • Product Shelf Life (Unopened)
  • Purchase based on Price
  • Recommended by
  • Resistance to Cold
  • Resistance to Heat
  • Stability
  • Time to Cure
  • Time to Dry
  • Time to Set
  • Use as a Filler
  • Use as a Finish
  • Viscosity Thin
  • Viscosity Medium
  • Viscosity Thick
  • Viscosity Gel
  • Waterproof
  • Water Resistance
Please add Comments, Corrections or Recommendations below this Post.
This is a good idea Wayne, but... you may want to break it down into how the CA is used.
For example, I prefer GluBoost for a finish, BUT always use StarBond as a glue and for filling larger voids.
I always buy Bob Smith Ind. ca glue. In fact, just ordered a set yesterday. I was contemplating trying gluboost but with shipping, would have cost $100. Cost me $45 for my set of BS ca. Just can't justify the difference in price.
I mostly use GluBoost at present, but I still use Stick Fast as I had a considerable supply. To clarify though, I use Stick Fast Wood Finish not Stick Fast CA glue. The Wood Finish has a longer open time and is more flexible (to prevent cracking) compared to their standard CA glue. - Dave
Went with Magic Chems because I could get it very inexpensively in good quantities on Amazon. I had never heard of it. I have no particularly loyalty to the brand. When I bought it I was working under the assumption that all CA glues were essentially the same. That may be entirely untrue. But what I've found after using it for my last ~100 pens is that I have zero difficulty getting a CA finish that I'm totally happy with using that. Only other CA I've ever tried was Hot Stuff. I couldn't tell any difference, except that the Hot Stuff was a lot more expensive.
I just switched to GluBoost. I had briefly been using some cheap Amazon stuff, then tried GluBoost on the recommendation of folks on this forum and love it. I still use the cheap stuff for sealing ends where it won't be seen, but for finishing it's pretty much Fill N Finish all the way.
Titebond and Mercury as I have both. Use it up and consider Glu-Boost. BTW, I have used the little tubes of CA from Harbor Freight. It would be interesting to see the chemical differences of the various brands. Looked and found methyl cyanoacryloate and ethyl cyanoacryloate as the two glues. Any chemists out there?
