Scratching My Head On This One
I will throw this question out there in hope to find a good idea I can steal (sorry borrow). Over the years and I mean many many years, I have been buying router bits of all kinds and sizes. I recently sold some large ones that I figured I would never use so cleaned some space. But I have been collecting 1/4" and 1/2" shaft bits of all kinds. But my problem is many times I would throw away the plastic wraper they come in and then wind up throwing in a box. Then when next project comes up I wind up buying same bit because I can not find other one. probably have many duplicates and so on. But last year a started to clean and organize my shop and that has gone real well and coming down to final little things to do. I decide what I am going to do is buy a bunch of the foam rubber mats that you can stand the bits up in. I do not want to build a cabinet with a rows of drilled holes. Just easier with this foam things. I need a way to store the trays. Was thinking attaching to some thin plywood to give strength and I can pull out a group at a time to see what I would need.
My question is has anyone done this and if so I would like to see a photo. I have a vague idea of what i may do but better minds may convince me to go another route. So before I commit I will see what everyone does to store their router bits.. The ones that come in a set I will keep in ther little containers. I have specific ones I use for specific jobs so will leave those alone too. But the loose ones I bet I have over 100. And they are scattered in boxes around the shop. I need to organize them. probably should have mentioned this too. Have no wall space to hang any cabinets. I either need to put on top of a cabinet as a stand up unit or I do have some space inside a cabinet I just cleaned out that had all my Makita 9volt drill and other tools. By the way, does anyone want to buy some Makita drills 9volt the old Cad batteries. ?
I used to have many router bits for all sorts of woodworking - Dovetail, Rabbet, Rail & Stile, etc. I thought about using foam as you mentioned, but I decided to use 3/4" MDF, cut into 2" squares. I drilled 1/2" or 1/4" holes and inserted the router bit shafts into the corresponding holes. I had emptied a drawer in my workbench and used that drawer for bit storage. I have since moved away from using routers, so I have sold all my bits. I have attached a couple photos of my bit storage blocks.
View attachment 389887 View attachment 389888 View attachment 389889 View attachment 389890
I just do not want to waste time doing the amount I have. I can never move away from a router. As an all around woodworker I just added some new ones I never used before so that will be an interesting learning curve. have a few projects in mind. yesterday I was cleaning out my cabinet that has my lathe mounted on it. i built that thing many years ago. In the drawers I have alot of bits I use at the lathe. Which may give me ideas of making something just for those. Now I crossover with alot of the same bits so maybe have duplicates and will make other areas for those. Those plastic cases as you show is what I was talking about. I know they are better for protection but they take up too much room and why I would always throw them out. I just bought a couple small cheap cabinets that I need to asssemble. I can use the drawers on them but to me it is a waste of space. I am keeping an open mind and hope to see more remedies.
John, this is along the lines of a more structured solution, and I was somewhat resistant to this, until I stumbled upon the Rockler Router Bit Storage Inserts. At $8 for 10, it isn't bad and I bet there is something similar out there that is 3D printable. What I found so appealing about these is that they are designed to hold both 1/4" and 1/2" shank!!!
Here is how I used them in the router table/cabinet that I built. The photo is from during the build, but you get the idea. This "drawer" is directly to the left of the compartment to access the router itself and each level holds 28 bits. I could have easily put 3 levels in the same space, but opted for visibility instead. Mine is not half full (yet).
I just cut solid wood squares about 6"x6"x2" and drill an assortment of 1/4" and 1/2" holes. Depending on the size of
the router bits, I can get about 20 router bits. It's an effective (simple) way to store them as they are easy to see and do
not take up a lot of space.
I think I did something similar to what you are talking about. This is an old picture, but I built trays into the side of my router table and pull the trays out as needed. Not fancy, but Functional.
This is why I p[osted here. Just looking at your set up I got 3 additional ideas that I now want to do. You have a PM. I would like to talk to you.
I lived in Hawaii many years. High humidity environment. I had made a quick-n-dirty router bit storage by drilling holes in wood. The wood would absorb and hold just enough moisture to result in rust on the bit shafts. I would recommend the plastic insert approach for any higher humidity situation.
Thanks and probably good advise. It is in my basement shop so never have to worry about that thankfully.
I filled the purpose-built drawer for 1/2" shank bits in my router station.
Over time, I accumulated a collection of other bits that needed a place, which could have been the extra drawer I made for that (at the time) future purpose.
Until I got the "round to it" I put the extras in a 4-24 compartment Plano box. I haven't needed to do anything different.
I have a few doubled up because they fit that way, and I use some foam wrap to keep the shanks from banging into the carbide. The two in the middle still have the rubber coating protecting the carbide.
Individual compartments are 2" x 2", and 1-3/4" deep. Plus there's a little extra space above the dividers.
It's not as fun as building something, but it's efficient, protects the bits, and doesn't cost much. At some point, I will print some clear labels.
Oh that is too neat man. Can you come over and do mine for me? I was looking for a 1/4" flush trimming bit this morning. Opened a box of bits and just shook my head. This will be a bigger poject than I am thinking and will need serious space for the amount of bit I have. I am sure I will be ordering more of those foam pads.
Hi JT,
I made mine fit in a drawer in my toolbox by I angling them so they didn't stick up too far. It was pretty easy. I just cut an angle on a piece or two of MDF and glued on a strip of pine add a base. I cut them to my desired lengths and spaced the holes to fit the router bits. I drilled them with a 17/32 drill so the bits slip in and out very easily. Then I glued on some printed labels to help me keep track of what they were. - Dave
Hi JT,
View attachment 389929 View attachment 389930 View attachment 389931
You guys are embarrasing me. I have way too many bits for such organization. I will just find a hole and put a bit in it. I think I am qualified enough to recognize the shapes I want but may have to measure some time for sizes. that is what calipers are for. have about 4 sets floating around the shop somewhere. Again organize will help this problem.
Hi JT,
Only just found this one and Wow that's a neat idea. Mine live in a variety of original containers , some buried in " safe drawers " sadly that means a lot of digging when they are needed and I must sort that .
I wound up buying a few of these and made a cabinet something like Mark did in post #5. Put it in a cabinet. I put all the other router bits that have cases and boxes under the router at the router table. They are the specialty bits. Some are sets. Easy to take out and look through them. The foam rubber tray holders work great.
https://www.rockler.com/router-bit-...96591839&utm_content=AssetGroup_100424_133047
I think you might like my suggestion. Your significant other...hmm
Build a cabinet with a shelf..
A pretty one. were the shelf is for Her.
And the cabinet below the shelf.... routah bits.
Yes inside the house. :)
You can thank me later !
nope not got that death wish yet …..
it a thought JT !
I find the packing form for PC or white goods works well. use either a soldering iron to merl the hole or a slightly small hollow punch revolved in it cuts it really well.
it a thought JT !
I guess that is another option. I am looking for the quickest way to get things organized in this shop. My plans to start projects already took a 2 month hit and we are heading to mid Feb and I have not started any of the projects. Not sure how much I will get done this winter because as soon as spring comes I have to get back to house projects. But I am rounding the corner to finishing most of those this year so I know next winter will be alot more shop time for sure.
That is close to what I have and use now.
I made a router center (with two routers) in 2002 or 2003 when I lived in Japan. I made wood holders for 1/2" and 1/4" shafts. In about 2 years, I started noticing rust on the shafts. The wood holds humidity and that in turn causes rust on the shafts. I lived in the Osaka area at the time, only about 25 miles from the ocean, which was ripe with humidity.
The rubbery foam does a LOT better.
I have more than twice that number of bits now.
PS, I left that router center in Japan because of its size and made an almost identical one once I got back here.
View attachment 391054 View attachment 391055 View attachment 391056
very neat Hank
