Using a wet/dry sandpaper on synthetics?
Woodchipper
Cleveland, TN
I use Micro Mesh that starts with 1500. Anyone use anything as 1000 or even 500 to smooth the surface then move to MM? Curious. Thanks.
I prefer zona paper, which starts at 600 equivalent and goes up to ~25000 or so.
I wet sand 400 & 600 then move to zona. Then finish with maguires (I'm testing another finish as well, but it's expensive so unsure). Also do the same for CA.
I use wet dry sandpaper. The black stuff starting at 1200, 1500, 2000 and them MM. Then auto polish. I love the finish I get.
For preparing both Wood and Plastic Blanks for finishing, I dry sand with sandpaper based on the roughness left by the tools when I finish turning with carbide tools. Typically it is pretty smooth to start with so I sand with 400 grit, 600 grit, and 800 grit before applying a finish. It is very rare that I start with anything lower than 400 grit, and sometimes I even start with 600.
After Finishing and on unfinished Plastic Blanks I wet sand using the Micro Surface pads. I often use the 1500 (Brown) pad two times to start off with - To facilitate this I actually have two 1500 pads at the top of my stack. Then I progress through the pads to 12000 (Gray). Depending on the result I may buff with PSI's Blue Compound on a Sewn Cotton Wheel followed by polishing on a "no compound" Loose Flannel wheel.
This is a grit chart that I made a few years ago based on the CAMI (Coated Abrasive Manufacturers Institute) scale and various published Micro-Mesh and Micro Surface charts for regular Micro Surface pads for Plastics like Urethanes, Wood and Wood Composites. Some of the missing data has been extrapolated.
Dave
Dave
So the "grit" numbers on micro mesh are not the same equivalent as sandpaper?
No they are not. I get mine, called Micro Polish Pads, from Turners Warehouse. I cut the 4" x 3" sheets so I wind up with four complete sets of 1.5" x 2" pads. The adjusted cost winds up being $3 per set - not too bad compared with the 2" x 2" pads from other sources that cost $12 to $22 per set according to Google AI. - Dave
When working with pure synthetic (as opposed to wood or hybrid material blanks), I sand dry up through 400, then sand wet with 600 and 1000 (just plain water). Everything from that point forward is applied with shop towels (scratch free, micro magic, novus, ren wax).
Hi all I am currently working with acrylic pen blanks, I don't know what the kit is but it's a box of 50mm sq abrasive pads
300 grit to 12000 grit I use a water and washing up liquid to keep the pads wet so that the dust/sandings does not melt back on the pen. I bought one of those make up liquid despencerd that you just touch the top of
Last finish I use an acrylic /glass polish. (Expensive) looking at trying T cut ….. as they say watch this space… whoops of joy or tears lol
I would encourage everyone to give this a try. I wet sand "acrylics" to 800, then move directly to the Novus 3-2-1 plastic polish system I get from Amazon, only using the course(3) and fine(2) components of the system. I did this and compared this to blanks where I went through the 7 Micro Mesh grades before the plastic polish step. I could not tell any difference so I ditched the Micro Mesh and now save myself some time and effort. This would probably work with other automotive style polishes with a course and fine grade, but I have not tried any outside of the Novus products...
I've also moved to using graded auto polishes in my process - as I have stated in other forums here before. I use a multi-grade compound from Rupes -Rupes Polish
I use a lot of Novus for cleanup on pinball machines (my second addiction) and it also works well, but I find that it is more prone to leaving a white film on things that requires a bit more cleanup with pens.
Kevin
I wet sand with Abranet starting as low as 80 grit for final shaping, if needed, and work my way up from there to 600 grit before moving to 1500.
