Obtaining pen parts isn't what I thought it would be..
CraigC
USA
Time for my newbiness to show. I thought you'd buy the lathe, turning tools, chucks, jaws, etc., and then buy the caps, clips, all pen parts, in bulk and get busy. But from what I've seen, you buy a kit for one pen, make it, then buy another kit and so on. Am I missing something? I also appreciate the poll I found on here referencing where you guys buy your pen parts/kits. Now I don't have to ask 😁 My blanks arrived today from Ocooch Hardwoods. I'm waiting on my pen starter kit from Rockler - supposed to arrive Friday. Guess I should attempt to turn a few before going nuts buying parts/kits.
Craig the best thing you did was find this forum. What you are talking about is kit pens and yes you buy them in kits. You can do kitless pens where you make all the parts or buy a few parts from various dealers. But that takes a whole set of new adventures. Look around the site and check out the library. it has a ton of info that will help. Ask questions and have fun. I will say a couple things. Not knowing where you are from but still does not matter you will find much better pricing than Rockler and yes Ocooch is a great source for all kinds of woods. I use them all the time but shipping is expensive so unless you buy in bulk you could overpay. Exotic Blanks is a very good source for kits and blanks as well as Penn State Industries. they are probably the 2 most used sources for things pen related. There are plenty more and some are more geared toward their kits. Not all vendors carry the same blanks and kits. bearra Hardwoods is another great source. You need to shop around. Then there are many vendors here that sell blanks of all kinds. Mainly home made. The finally you can go down the rabbit hole and make your own blanks by casting or cutting them from larger sources. But as far as kits go there are a ton of different kits. Which makes it good because you can reach many different people with theme kits if you get into selling. You have ntered the twilight zone so be prepared to let go of some $$$$. Good luck
JT has given you great advice.
I'd add a couple of bits of advice:
1. Not all pen kit manufacturers have the same quality standards. Some "Slimline" kits have transmissions (the bit that moves the refill in and out) that are junk, others are very well made. It can be tempting to buy a bunch of inexpensive kits from a no-name vendor, but it might be money thrown away if the mechanisms are flaky. If you intend to sell pens, stick to the reputable vendors until you are confident that you can tell the difference - because once you sell a bad pen, your reputation is on the line, that pen had better work for more than a couple of weeks.
2. Think before buying "single use" gadgets. You have a lathe, it's a simple task to make (for example) a couple of inserts to fit into the headstock and the tailstock making a very effective "pen press" (to press fit pen components into the barrels after you've turned and applied finish). And if you don't have a drill press, you can get chuck jaws that hold a pen blank, and a Jacobs chuck on a Morse Taper that fits into your tailstock. This also can have a longer travel than the quill in a drill press, which saves having to stop and reposition the blank if you can't drill all the way through in a single stroke.
3. Check out the posts that Mark Mayo posted in the last few days with video clips of how he does certain operations - cutting a blank to length, drilling a blank, gluing the brass tubes into the blank. There are many ways of doing most things, but if you are new to it simply being shown one way that works can get you started, and you can experiment and find your own way later.
4. Do not cheap out on personal protective equipment. You have one set of lungs - protect them with a quality respirator that filters out dust even below 1 micron. The 3M half-mask respirator is a good choice at around $40 (and can include filters for volatile organics, which keep out nasty things like fumes from finishes). A dust collector or an air filtration system is a good idea, but they are spendy. (Note that a Shop Vac is good at picking up chips, not the same thing as dust collection.) Protect your eyes with Z81+ safety specs or (even better) a Uvex Bionic faceshield. You can get them for $35 or less, and they will keep shrapnel from messing up your face and potentially shortening your turning career.
Excellent advice/information!
From several years as the OSHA compliance and safety person for my employer, I would add that a mask style respirator will not seal properly on anything more than 5 o'clock shadow. Beards are NOT air cleaning filters, nor do they provide sealing surfaces.
Be safe. Have fun!
Once you've tried different styles and manufactured pen sets you'll find the ones you like. Then you buy in bulk. Just because they look the same doesn't mean they all work the same or hold up as well, and names can be the same but manufacturers are different so h can mean slightly different tube sizes or plating quality. When I first started and was only turning one style of pen I found a a good price and bought several sets. Over 20 years later, I still have a large majority of those exact sets in a box collecting dust because I realized I didn't know what a good set was yet or what I liked. Play around with it, have some fun and ask questions here. You'll figure out rather quickly what you like.
Um.... What the other guys said for sure.
I'm a huge fan of Exotic Blanks because they buy from multiple manufacturers which allows me to save on shipping. Their customer service is real good too.
To reiterate on a theme. If you're looking at the same pen for two different prices and there isn't some obvious reason for the difference (e.g. plated with 24 k gold) then you should absolutely spend up and get the higher priced option.
