Sealing the ends of a finished pen blank
mmayo
Tehachapi, CA
Many people do not do this step and I encourage you to develop this habit. People will touch your pen and they will put sweat in the junction between the hardware and your newly beautiful blank. To avoid this problem, I sand the ends, and then I seal them with thin CA glue.
I always do this. I simply fold up a piece of paper towel to use as a blotter, drip a few drops of thin CA on it, then push the pen blank down onto it and twist it back and forth a couple of times. Repeat a couple of times.
I started doing this because I was occasionally having adhesion problems with my CA finish on the ends. I would get a separation that looked like a gray-ish spot, caused by air between the finish and the blank. Sealing the ends seems to have fixed the problem for me so it just became part of my standard regimen. - Dave
Yes; seal the ends. Sand / trim the ends and put a drop of thin CA on wax paper. If you are careful no CA gets in the tube. When cured, sand ends.
I think sealing after CA glue application and after flush sanding the blank using a paper towel just seals the end, but NOT the rest of the blank. I never get excess on the part of the pen visible to a customer.
This is the first I've heard of doing this. It sounds good, but do you worry about popping the CA finish off the barrel when you press the hardware onto the end? I carefully sand off all the extra CA on the ends.
Since using this method and my application method for CA I have not popped CA. The last time I had issues with splitting the blank was with the dreaded Sierra. Now that I use a Diamond Knurl ballpoint by Ed at exotic blanks I never ruin the newly finished tube.
I don't know about you but with 4 coats of 5 cps CA followed by 12-16 coats of 50 cps CA - my finish sticks. I apply all of the coats to dry, newly DNA cleaned blanks. Any use of BLO or anything else causes issues.
I've noticed that on the ends of a couple of my pens, do you put the CA on the ends before you apply the CA on the rest of the pen.
I began sealing the ends years ago after I realized moisture from wet sanding can wick in under the finish and create cloudy or discolored areas. I seal them after I sand or mill the ends to the barrels ( with ultra thin CA) so it wicks in and doesn't build up a thickness. After the blanks are turned and the side areas get a ca finish there's no chance of any issues with wet sanding or finishing. Never had one crack since either.
