Lazer Pecker 2
RDH79
Rimersburg, Pa, USA.
Happy New Year everyone.
Does anyone use a Laser Pecker 2 engraver on wood pens.
What I see in the demos for the LP2 is doesn't burn very deep.
The price of the 4 or 5 is too much for the amount of us and my budget.
I don't own one but I think that model came with a 5w diode laser. I have engraved on pens and other stuff with a 3.5w laser. It should burn just fine. If you engrave something and you want it deeper, do not move the item you are engraving, just have the laser go back over it another time.
Dropping the head is gonna lose the focus on your laser. The best way is just run more than one pass when engraving.
I just picked up a LP1 a few weeks ago, just for personalizing wood pens, and it does a great job. The LP2 is more powerful and faster, so I expect it will be at least as good. I did a couple of test runs on scrap first to get the settings right. In the app, you can set the power and depth as a percentage from 0 to 100, as well as the number of passes (up to three, if my memory is correct). I have mine at 100% power, 60% depth, and just one pass, and I'm very happy with the results. I could probably have done two passes and it might have come out darker and deeper, but I didn't feel the need to. On this pen below, I did the rough sanding (150 & 240 grit) before engraving, then finished with 320, 400 & 600 paper, and sponges up to 3000, before finishing with EEE and Shellawax.
My only issue with the LP1 is the flimsy tripod. I drilled foot holes into a plywood board for a base to keep it from collapsing, and that's been working fine so far. I would recommend the LP2, as long as you're only doing hardwood or stabilized wood - though it may also handle plastics, I'm not sure. If this LP1 ever dies, I will definitely upgrade to a LP2.
I use the lp5 with the 20w fiber and 20w diode and it will 3d emboss wood and metal. Surface engravings should be fine with the 5w in the lp2 but i'm not sure how deep it would go if your looking at anything like decorative inlays with resin and such
Danny Thank You for all the information!!
That pen looks great!!
Do you have a turn table for it or does the pen just lay still?
Thank you!
I cut a shallow groove into a small block of scrap pine (about 3 x 3 x 3/4") and lay the blank on it to hold it steady and engrave exactly where I want it. The Laserpecker app lets you preview before doing the actual engraving by projecting a rectangle around the area that will be engraved, so you can check the size and alignment on the blank.
This is a couple pen engravings I did a while back. I did these with my little Neje 3.5w laser. The Texas emblem was a few passes and filled with mica powder.
