Dieseldoc
Criss cross bowl. 8 Walnut Spline in lays in this 8 inch Ash blank make up the bowl 8x2.24.
Ken: Agree as it's start come together, I found the 8 inlays looks much better that the 12. Still working out some issue on alignment.I love it. I think this is my favorite one you've shown.
JT: Didn't have one for this go around but going to start another tomorrow and will send to a photo or two during the process.Very interesting. Do you have any photos of the blank before turned? Love segmenting.
now that's a cracker ! It must have taken a while to centralise properly and a whole lot of patienceKen: Agree as it's start come together, I found the 8 inlays looks much better that the 12. Still working out some issue on alignment.
This one was a real pain as the blanks was very dry Ash that I had in stash for several years and end grain was a killer to keep from tear out.
However it did come out ok. With very very sharp edge on the shear mode.
Inspired by Kip Lockard You tube on the process. Getting alignment down was big problem when making the jig.now that's a cracker ! It must have taken a while to centralise properly and a whole lot of patience
Well done
Construction notes would be appreciated ?
I like the over and under illusion. Working on a project that does something similar this winter.JT: Didn't have one for this go around but going to start another tomorrow and will send to a photo or two during the process.
Lee: Blade is Diablo 10/60 fine finish 1/8, titebond II extended time glue , and Model machine mini drum sander to custom fit splines. Also the splines are not at 90 degrees and that is why they look little fatter.Did you configure the thickness of the splines to the kerf of your saw blade?
5/32" or 3/16" Kerf? To my eyes, it looks a tad wider than 1/8"
