I have just gotten into woodturning and am trying to maximize my spend by getting versatile tools that I can use for multiple tasks. I have only started making pens right now, but I do plan to get into other items like pepper grinders, kitchen tool handles, and other things like that. I have a gift list in my head that is a mile long as I think of those I love and how I might be able to bless them with handmade items!
I bought the PSI Utility Grip 4 Jaw Chrome Lathe Chuck System - initially I wanted to use it for drilling pen blanks on the lathe with a drill chuck in the tailstock, but I have found it to be pretty time consuming drilling on the lathe. After pondering a bit, I came up with a unique way to use this chuck with my drill press to drill blanks. I realized I had no need for the 3/4" x 16tpi headstock spindle adaptor that came with the chuck (I have a 1x8 spindle). So, I welded the adapter to a piece of 1/8" steel I had laying under my welding table.
I clamp that plate to my drill press table and it will hold my blanks steady as a rock. I can now drill blanks very fast, straight, and true. I am attaching a couple photos to show how I have it setup. It's not very pretty, but it works really well! I think it will work great when I get to peppermills. I will just swap out the jaws for the larger ones and drill away. I am using the small #1 step jaws that came with the chuck - they will hold the blank on the four faces.
One thing I have noticed is that on blanks that are not quite square, it is a little tricky to lock it in parallel to the bit. I simply rotate the press table away from center, slowly lower the bit down with the press off to check for parallel and adjust the blank in the chuck until I get the right orientation.
I'm also using it for squaring my blanks before turning. I wrap the blank in leather and tighten the chuck down. Then, I put the barrel trimmer in the drill chuck. The leather gives just enough flex to allow me to press on it a bit to line up the trimmer while I lower it into the tube. I can very quickly trim/square my blanks using the setup.
Hope this might help somebody else!
Kind regards,
Chris
Kind regards,
Chris
