What grit for squaring jigs with sand paper on the lathe?
jschoolcraft
Virginia
Basically what the title says.
I have had https://www.woodpeck.com/ultra-shear-pen-mill-inserts.html on my wish list for a while. I had a bunch of the cheap mills that need touching up with a hone like every blank.
I bought Rick's sanding setup for the tail stock and it works great.
What isn't so great, even at 80 grit, is how long it takes to get through a large number of blanks. I'm not a production turner but sometimes I'll prepare 20 blanks at a time and then turn them down during the week. When I turned the Designer Twists I did 15 pens ( x 2 tubes per pen, x 2 faces per tube == 60 faces). I started with 120 and went down to 80 and that whole operation probably took 90-120 minutes over 2 days. I had the shop vac collecting dust, I regularly cleaned the disc, was going about 500-600 RPM.
Is it grit? Technique? Something else? I like sanding as much as the next person and my volume is by no means huge.
I was really hoping that wishlist item would be a miracle cure but it's easy to find 50+ results on this forum that all say ditch the pen mill and go to a sanding setup.
There's always a balancing act with how long you cut the blank before drilling and gluing in the tube. I shoot for minimum extra length on the blank these days specifically because I hate when it takes forever to flush up the blank with the end of the tube on the disc sander :D
How much are you taking off when you square them? I usually trim the excess off mine with a miter saw fairly close to the tube and then hit them on Ricks squaring jig. I use 80 grit and it usually only takes 10-15 seconds tops to get to the tube.
Likely a 1/4" on one side, like a 1/16" on the other side. On a regular basis.
Yeah, I need to build that jig for the bandsaw, I'm eyeballing it with a sharpie for the most part now.
Here is what I made for sanding but use a pen mill for blanks. If there is a lot of material past the tube, I run it through the bandsaw.
The jig for the bandsaw to cut close to length on the blank is really the way to go. I cut mine (if needed) fairly long compared to the tube so I can drill deeper than the tube and then I cut to length. I try to have between a sixteenth and no more than an eighth on either end. If you've got up to 1/4" on one side then you're spending a lot of time trimming that off. That's a lot of sandpaper or trimming mill life to go through 1/4" each tube.
For the record - I sand on my disc sander, my drill press has a wobble so I don't bother with using the mill. I think I have 120 on my disc?
What I do is whatever excess I have I take off with my belt sander. I get real close to the tube and then switch to the lathe and sand. And if I have alot excess I will cut that off with my scrollsaw.
You should be able to get within a 1/32" of the tube length. I have a jig that clamps the blank and uses the tube as a reference. Cuts the blank that same 1/32" longer than the tube. Takes only a minute or two and is more a matter of making sure the end of the blank is perpendicular to the tube.
For wood blanks, I just cut to this length. With synthetic blanks, I cut blanks longer, drill to the required depth, then trim the excess.
This is the jig I made for my table saw sled. the key is that the slider "L" is just long enough so it cuts the blank the same length plus 1/32" longer than the brass tube at the upper right.
https://www.penturners.org/media/table-saw-blank-cutting-jig.23881/
I have a crosscut sled on my table saw and trim to within less than 1/16" on that before using a sanding jig.
do you eyeball and draw a line? or just sneak up in multiple passes?
My table saw currently identifies as a workbench with half my garage stored on it :|. I'm slowly changing it's identity back to a table saw
I was going to make a version of the one hanging around for the bandsaw, it's on my list anyway. Hopefully I'll have my table saw back in service this weekend.
You don't need a fancy sled, just use the T-square that came with your bandsaw. Hold the tube on top of the blank with the end flush, bring the blade up close, eyeball 1/16" long and make the cut. If you center the tube with 1/32" on each side it will take 10 seconds to sand it off using 80 grit paper.
I think a bandsaw jig will be just the ticket for you. Since it uses the actual brass tube as a gauge, my jig repeatedly leaves only about 3/32" to square off between the two ends - so not a tremendous amount to remove. I use 120 grit paper on my sander, and like you I keep it clean with one of those big eraser-like sandpaper cleaning sticks. - Dave
Multiple passes.
I agree with @rherrell that you don't need a fancy sled. I use mine because I store it on the table saw so it is always there.
I use the table saw because I get little or no blade deflection with my full kerf blades, whereas with the band saw I struggle with blade deflection, especially with light cuts.
I use a depth gauge and a japanese fine tooth pull saw to get close then either sand ( rarely ) or use a tube trimmer GENTLY with the blank held firmly in a vice on my drill press table. I cut to within about 1/16 using the saw . Depth gauge ( shows me exactly where the tube is inside the blank . If it doubt err on the side of extra length.
My bandsaw didn't come with any kind of miter gauge or a fence. It's an old craftsman 12" bandsaw/sander combo I got off marketplace. The bed does have a miter slot, so there's that.
If you have the miter slot that's all ya need. You can make the sled. Mine is decidedly not pretty but was pretty quick and simple to make.
