What is your single favorite pen you've ever turned?
BHuij
Utah
Not your favorite kind of kit, but your favorite pen you've ever made? Or if you can't choose a single favorite, tell me about one that you found particularly memorable. What about it made it important?
Mine might be a European Classic fountain pen. This exact kit, as near as I can tell, though I would have purchased it at WoodCraft in about 2007 or thereabouts. I was 15 or 16 at the time. I made it out of kingwood. I did not do a good job matching bushing diameters, I wasn't particularly good at sanding, and I had not yet heard of CA finishing. So I probably dry sanded up through 600 and then used Mylands friction polish. I bet that kingwood looked awesome for all of 4 minutes before I handled it for assembly and it was never very glossy again ;)
That was the first fountain pen I ever owned, and I was enamored with the idea of filling the converter with ink. The wide world of color options was in front of me. I bought a bottle of Aurora Blue and used that pen for years. It was the genesis of my pen obsession.
Now I'm 33. I still have that pen. It's terrible. It's not well-turned, the finish is nonexistent at this point, there are obvious issues with the diameter of the wood compared to the fittings. The rear finial on the body came out at one point and I couldn't get it back in, so I took a dremel to it to make it fit, It's ugly and loose, and I think it has some crusted-on superglue from an attempt somewhere along the line to make it stop rotating in the brass tube. This is a pen even a mother couldn't love. To top it off, it's not even a good writer. It came with an IPG #5 nib as is standard, and it's not a good one.
Having owned and written with probably 50+ fountain pens over the past 3 years, I've almost never run into a nib (even a cheap one from AliExpress) that can't be substantially improved with super basic tuning. Disassembly and thorough cleaning of the nib and feed. Aligning the tines properly with a loupe and gentle finger pressure where necessary. Adjusting the tine spacing with brass shim stock to get the flow where I like it. And 10 minutes spent polishing with 12,000 grit micromesh, 1 micron mylar, and 0.3 micron mylar. This treatment will make almost any nib into an excellent writer. Not this one. I have given it a lot of TLC and it is still skippy and scratchy, and I can't fathom why. I don't know how I wrote with it for so long.
But I have this janky old pen to thank for being my gateway drug into a hobby I really love, which has in turn led to me meeting some new good friends via pen pals, starting and running a semi-annual international photography print exchange on Reddit, and keeping my life better organized with journaling and bullet journaling.
I am considering restoring this pen. I could get a replacement kit for the fittings that are damaged. The wood itself is fine, and with a bit of reshaping, sanding, and a good CA finish, could look and feel excellent again and match the fittings for diameter. And a good #5 Bock nib would be a night-and-day difference in writing experience.
Mine favorite (so far anyway) would be a magnetic cap rollerball "Franken-Kit". I made it using a PSI Magnetic Graduate kit for most of the parts but with a top Cap and Clip from an Exotic Blanks Diamond Knurl Rollerball kit so that I could put a custom top finial/cabochon on it. It has gunmetal plating and the blank is an Australian Burl Hybrid that I bought from Exotic Blanks at the 2024 MPG. - Dave
I have several that I call favorites for different reasons. These two would be the ones I'm most proud of. As far as these two go I'd have to go with the snakeskin because I don't know if I could get another fang for the finial. The Abalone is right there because it took me several tries to get the tooth in the finial without bubbles or separation plus the shark vertebrae in the band is pretty cool. At least I think.
This is one of my favorites. It's a jr Emperor with Bloodwood.View attachment 387691
Jim it is rare we get to see one of your creations and have to say stop hiding them on us. First I love this kit. One of my favorites. I love the wood. Again one of my favorites and they make a great combination. Fit and finish are right on the money.
Impossible to chose because I dabble in so many different styles and many times the kit and blank make the combo stand out. The pens are made the same way by turning and finishing. But different made blanks and themes can push those lines. I will just say I have yet to make that all time favorite pen yet and leave those to choosing which one of my pens they like. But I won't lie I am proud of just about all my pens and not abit ashamed of showing any of them off.
I think this is my favorite so far from the ones I made:
My most favorite pen was a slimline twist. It was one of my first turned as well as was from Elm my father helped harvest. Also, being Elm it had such a nice texture to the turned wood that I left it unfinished. I dont normally like slimlines because I have larger hands and they tend slip when I write with them but this pen with its unfinished texture stayed put in hand.
Sadly that pen has been lost.
Now my favorite pen is an Eclipse I made from Bog Oak. Silver Chrome with the black coloring of the wood makes it stand out. also being a Parker style refill it writes tremendously. It sits in the backpack holder of my PostIt notes holder on my desk.
It's a toss up between two favorites. My first FP ever, was a Baron with Honduran Rosewood I made in 2008 for a swap partner in Australia. BigShed here on IAP. I knew nothing about finishing aside from friction polish, which I never liked. Some members suggested Lacquer. I had already assembled the pen, and was prepared to send it as it was. But I boldly decided to tape off the metal parts, and try spraying it with Deft. I believe there were four coats, maybe more. I let it dry for a week or so, then wet sanded, and polished it.
My second was an Emperor FP I think it was Black Rhodium plating, with a $100.00 nib from Craft Supply. The material was 1930's Bakelite.
Thanks for all who display their favorites. I have found that the "larger" pens sell better than the Slimlines which also need to add some bling.
One source= plagiarism; two sources= research.
I've seen this pen before, it's absolutely gorgeous.
How do you find the writing experience? I haven't played with the Magnetic Graduate body before, partly because there is not one by two fairly harsh looking step-downs in diameter around the section. Seems uncomfortable to grip.
Also curious where you got that vivid red acrylic/resin. I realize it came with a hybrid blank so you may not know, but I've never seen a red synthetic that looks that good and I'd love to get my hands on some!
One of these days I will try your custom cabachon guide out, I think it really adds something to the overall design.
