My first clip
NGLJ
Surrey BC, Canada
I realize that the "to clip" or "not to clip" debate might be endless! To be honest, I am not sure myself. So, I figured that I would try using a clip, and discover the challenges involved. The nib/section is from Turners Warehouse, and the clip is a Beaufort, via Turners Warehouse. The material is Pearlux from William Wood-Write. The finials are ebonite. It could be just me but I found it quite a challenge because you are now constrained by the dimensions of the clip. I decided to size the cap to be the same as the outer dimension of the clip ring because I like slimmer pens. That might not have been the best choice because any slight mistake in turning the cap might cause an issue, and indeed it did. It wasn't a disaster but could be better. On reflection I should have chosen a clip with a smaller ring diameter, and buried it in the cap - next time. All in all it was a good learning experience, and despite the clip and cap finial not being perfect, I am reasonably happy with the result.
Nice job Graham.
You have discovered the exact reason why I moved to making my own clips. It's a lot more work, but it's also quite satisfying.
It's also another rabbit hole. LOL
Nice job Graham.
It doesn't take long to discover that there are lots of "rabbit holes" to fall down :p. I guess we are cursed with the "curiosity gene".
Having now kind of "graduated" to "kitless" pens, but still very long way to go compared to the amazing creations that I see here, I took a look at the first pen that I made about 3 years ago, I think. Time tends to have less meaning in retirement, and the memory constantly plays tricks on you! My reaction was, "did I really make that piece of cr.......". The upside is that at least I have come a long way since then :). I have to attribute a lot of my progress to the wonderful people here at IAP!
I now find myself, like many I suspect, asking myself the question, "how much kit vs kitless". Having crossed the pen makers "dessert", I don't see myself going back. This prompted me to check how many kits that I have. No surprise, I have way more than I thought. So, my current activity is making most of my kits to reduce inventory. Made about 40 so far, but still 30 to go :(. Some lucky people are getting a nice pen. I already have some favored recipients in mind. I will continue to buy kits, but only single barrel.
