360 herringbone with roller or fountain option
See more from Eckspec2
"Obstacles de la vie"
So this is my first completed pen this year, not because of any great difficulty although there are a lot of elements, life just got in the way, hence the name.
Walnut, Padauk and Holly, black tulip veneer, black and red pvc accents and black acrylic. I made an option of fountain or refillable roller section.
What are the internals of this - this looks similar to what I want to make. Its truly stunning!!
Cheers
David
Cheers
David
Thanks David, there's a lot dimension involved as I had to make an acrylic core and finial for the barrel and a similar idea for the cap and sections. The internal for the cores are - barrel is 9.1mm internal diameter to allow for M10 x 1mm thread for the matching section and also allow me to mount on a mandrel for turning and shaping. Cap is 12.3mm internal diameter to allow for a triple M13 x 0.8mm thread ( the threaded collar on the barrel matches this). I generally use Bock #6 nibs and carriers for my fountain pens so threads and sizes are based on and around that. If you need more information I'm happy to make a diagram , may take a day or two though
