A D&D themed bottle stopper
jschoolcraft
Virginia
I got glued the dice together to the top of a medicine bottle then filled it with epoxy and put it under pressure.
Drilled it for a stainless steel bottle stopper thread and threaded it on the mandrill. Probably a step too small on the bit, it took some cranking to cut threads on the inside of that six sided die.
Turned it and sanded forever, bonus pick of my blister from trying to remove radial scratches.
Start to finish.
The astute observer will notice two other blanks. The pink was too opaque. The yellow was alright but the die was off center and poked out of the bottom.
I'm going to go out on a limb and say that if you are getting a blister from sanding out scratches, you may be using too much pressure. This is likely how you are getting the scratches in the first place. Use less pressure and let the sandpaper do the work!
I like the idea of the polyhedra dice in a bottle stopper!!
Trust me, it's not that flimsy a limb. I'm definitely trying to control my "bigger hammer" tendencies in all aspects of my wood turning :)
Thanks!
