Woodchipper
I have seen a lot about Glu-Boost which is formulated specifically as a pen coating. Chemically, what is GB? Researched CA many years ago and had some questions for a chemical engineer. Inquiring mind wants to know.
GB has adhesives and fill and finishes. Both have adhesive qualities but only the "fill and finish" is meant for finishes because it has a flexible quality making it less brittle so it doesn't crack like others.I have seen a lot about Glu-Boost which is formulated specifically as a pen coating. Chemically, what is GB? Researched CA many years ago and had some questions for a chemical engineer. Inquiring mind wants to know.
I was at a conference and also heard that the new formulation of Gluboost was designed with pen makers in mind. It's flexble vs rigid.I'm not sure where you got that idea, Gluboost was initially marketed to luthiers for instrument repair, not pen makers.
The company website is gluboost.com, I just nosed around looking for the material safety sheet (which would typically list the ingredients) but couldn't find one.
If you click the "contact" button and ask them for the safety sheet they'll likely share it.
More pen makers than luthiers?I was at a conference and also heard that the new formulation of Gluboost was designed with pen makers in mind. It's flexble vs rigid.
