Raising Cane
See more from WriteON
WriteON
Florida & Pa
These are fun to turn/finish but no idea what to do with them. Gave a few away and have most on a display stand. They are slightly heavy. The handle will crack a tile if dropped on the floor. The dowels
& handles are expensive. Tend to use a few sanding pads for finish. Other than being impractical, cost out of proportion and take up space I enjoy putting them together. The latest for the rack. Bloodwood with 1 coat of Tru-Oil. Rubbed gently with 0000. Pledge and buff.
Unique. Could be considered a deadly weapon with the beak.
I have an interest in defensive cane fighting. A special hooked cane is used however yes this will dazzle. My favorite handle is the skull. It is a deadly striker. And the tip has a spike with the rubber tip unscrewed.
It could be considered a magic wand. I have a magic wand (aka a tire checker or fish stick) that I turned. I carry it whenever my dog walks me just in case I have to use magic on someone or an aggressive animal. Better safe than sorry.
A few years ago, I made a cane just as an experiment. My challenge was that a cane shaft is longer than the bedways of my lathe, so I came up with a solution that involved turning the shaft in three sections that I later joined together with dowels. That first cane was made of ash, but with walnut accents at the joints between shaft section.
Rather than using a commercial handle, I turned one on the lathe with a mortise on one end to receive the shaft. To make sure that the joint between the handle and the shaft was secure, and to reinforce the handle, I drilled a hole lengthwise through the handle and through the tenon on the end of the shaft, and epoxied in a fiberglass rod.
The project presented some interesting technical challenges, and was a lot of fun.
A few months later, wife took a fall and ended up needing a cane. She's shorter than me, so the cane I made was too long so I got to make another one*. This time, we were anticipating some travel and the need for her cane to fit into her carry on bag. So I made the shaft in four sections, but rather than using a glued dowel in the middle joint, I embedded a length of 3/8x16tpi allthread on one side of the joint, and a matching threaded insert in the other side so that joint could be disassembled.
Since then, I've made several others. One was made from a sapling I cut down in the forest behind the house so the shaft is a more natural form rather than straight turning.
* cane length should be tailored to match the user. Ideally, the cane should not be shorter than the dimension between the user's wrist and the floor when standing normally. A bit longer is OK.
Where to buy? I'd like to get a Rattan cane for defensive cane training... Cannot locate. Any suggestions?
There is a threaded joint (male/female) made to construct a multiple piece cane-walking stick. I get them and all cane parts from TreelineUsa.com
Dowels or the threaded male/female joint screws from https://treelineusa.com/ Maybe they can be found cheaper elsewhere.
I made few 2-3 piece canes. Can also add a brass ferrule. The parts add up but make a nice travel cane.
Just in from Cane Masters.... finish is Crimson. Looks like the Tung oil was omitted...I might rub a few coats on.
I made a bunch several years ago. I put rubber crutch tips on them
