Tube cutting?
ed4copies
Local Chapter Manager
Racine, WI, USA.
I use a pipe tube cutter from Home Depot. Does cause an indent in the tube sometimes, but that can be fixed by measuring long and cut off when flushing the ends, or a reamer.
I use that little chopsaw with the fence and stop lever to cut all of my tubes. It's the quickest and easiest method I've found. I use the stock tube to set the stop lever and just keep cutting one after another. (Measure once and you're done). It leaves a slight but on the cut edge but is easily removed by rolling the tube pinched in sandpaper.
Blades are easy to replace with just a screwdriver.
I wrote a short article on how to cut brass tubing to length. The photos show my table saw sled and near the bottom a blank cutter. The "Hold-Down" prevents the saw from launching the cut pieces.
https://www.penturners.org/resources/brass-tubing-cutter.305/
Most every saw will leave a burr on the cut end. Take a reloading deburring tool used to trim brass shell casings to remove the burr.
You can remove both the outside AND inside burr with this tool.
https://www.amazon.com/McJ-Reloading-Tools-Deburring-Essentials/dp/B07QGF5BRH
I looked to see if Ed sold these, but could not find them. (Sorry Ed!)
I bought this over the winter to use when deburring tubes after sanding. Another IAP member showed it to me and I wish I'd followed his advice a long darn time ago. You can get single tools for less but I splurged and grabbed the one that had refills.
That's what I purchased many many years ago and use it daily after squaring blank ends on the disk sander.
