Workshop setup
Bucky
Queensland, Australia
I live in a small farming community in Queensland, Australia. My workshop (shed) is a 4 bay, corrugated steel farm shed. In it I also store my car, ride on mower and associated equipment, plus timber storage. I effectively have 1.5 bays for woodworking. I have an older lathe and have recently ordered a Vicmarc V150 V2 EVS to do mainly pen turning. I having been googling to find some ideas how to set up an efficient area. I will need to make a suitable stand and provide some decent lighting. The shed has no lining on walls or ceiling. I only have one available wall that could be lined. I have 4 weeks to wait for my new lathe and construct a pen making area. Guess I'm just looking for some ideas.
Clive; Making the most of the space you have is always important and no-one anywhere EVER SAID, "I have too much space!". Your lathe (and other tools) needs legs, or a workbench with retractable rollers so it can be moved easily. Just as important is dust collection. The dust collector can double as a vacuum. Protect your lungs! You only get one set. An overhead fine dust box will help clean the air. This will keep dust from getting into other areas.
I keep most of my stock and kits in heavy duty utility boxes. Buy enough to keep them all the same. These are about 18" W x 24" L and 12" H (46cm x 60cm x 30cm). The bottom box has a flat movers dolly attached and other boxes are stacked on top. Labels on the front and back.
I'm sure you will get additional suggestions.
I have dust collection and overhead filter. I also have a bandsaw, drill press, table saw, router table, etc. My current lathe is on a small table jammed into a small area. I was looking for some ideas to make it more friendly to use. I do have an unlined wall and could remove the bench that is there, line the section of wall and make some sort of false ceiling to help reflect the light. I have tried googling workshop tours but nothing stands out. I may just have to move everything thing and rearrange again.
Bucky, I have all the things you list in my single bay garage shop. I also park my car in there when not working in the shop. EVERYTHING in my shop is mobile. If it didn't come with casters, I have added heavy duty locking casters. If I built it (and most of it I did) I put on heavy duty locking casters. I don't have to move things around to do everything, but when I need to it is easy. Everything is arranged around the edges of the space.
I do pull my lathe cabinet away from the wall when working so that I can get the dust collection connected and have it arranged so that my workbench is directly to the left.
The other time I move something is if I am cutting full size sheet goods on my table saw, then I move it to the center of the space and use my small mobile workbench as an out feed table. I don't do this that often though because my rip fence is limited to 30 1/2". I typically break down sheet goods with my track saw first and then I can use the table saw in its usual location.
My new complication.... I just ordered a Precision Matthews PM-1022V Metal Lathe. Now I have to rethink everything and figure out where it is going to go and how it is going to impact my workflow!
Hope this helps.
David
One of the areas that might help is blank wall space. A light duty, no it won't support your lathe, hinged work prep area can be helpful. Sturdy hinges and legs that lock in place can provide a staging or prep area for tight quarters.
few suggestions
1 paint walls , ceiling etc white to reflect light and make easier to clean ( heresy I know!)
2 line the wall with ply or something you can attach french cleats to so you can vary your layout as you want to later
3 draw a scale plan on paper of the space and your major tools then tryout various layouts. Look at best light areas , power supply points etc
4 always instal DOUBLE SOCKETS , you can never have too many power options available
5 rubber mats , or old carpet on floor are kinder on your feet , warmer ( prob not a major concern in Aus) and kinder on tool edges when you drop something!
6 LED lights are phenomenal and cheap to run, if you get ones with switchable colour intensity you can choose the light balance to suit your needs in each area
7 moveable tool cabinets are your best friend
8 look at grinder position vs lathe position , not neglecting dust collection in that area too
