Buckeye Burl, Gold and Gunmetal
See more from jrista
jrista
Colorado
These were a couple of re-dos. I did not like the materials I had originally chosen for the barrels, so I disassembled them and started looking for a blank that would do them justice. I eventually found this buckeye burl blank that was just to die for, and was the PERFECT match for the gold and gunmetal on these two beautiful kits.
Ballpoint Pen - Finial Twist - Cirque - Buckeye Burl - Gold and Gunmetal - 12.jpg
Ballpoint Pen - Finial Twist - Cirque - Buckeye Burl - Gold and Gunmetal - 10.jpg
Ballpoint Pen - Twist - Elegant Sierra - Buckeye Burl - Gunmetal and Gold - 2.jpg
Been working on my photography setups. Lighting, this round. New lamp with 3000k, 4500k and 6500k temperature settings that is designed kind of like a tall loop, produces some interesting reflections on pens like this. Which I think helps bring out some of the details in the metal parts, like the bands and clip on the Cirque.
  • Ballpoint Pen - Finial Twist - Cirque - Buckeye Burl - Gold and Gunmetal - 11.jpg
Beautiful pens! Your photos are very well thought out and look great! Buckeye Burl always looks great as it's always different and when turning it down there's always good surprises.
One of these days I am going to get into photographing my works better. may need to upgrade the camera too. It is on my long list of to do things. Nice job on both the pens and the photos.
Thank you all, for the comments! :)
I actually started a thread (unposted yet) to describe how I'm doing my photography these days. It might take me a day or two to fully finish it, but I'm describing each aspect of the setups, from design, to lighting, to props, etc. I figured I've learned enough that I should share with the community. I do use a nice camera, but...I think as long as you have a bit of control over your focus, and the right focal length, you really don't need anything particularly fancy. In my case, I choose to use a 100mm macro lens, as it gives me a lot of latitude to get close in without losing the ability to focus, and somehow (which kind of surprises me) it gives me a nearly perfect FoV. On some cameras, the optimal lens might be a 50mm or 70mm, once you find that sweet spot, then you are pretty much golden for this kind of closer up photography.
Thank you. I have spent some time exploring what other sellers do, and some people have truly phenomenal product photography. Not just pens, all kinds of wood items (and other hand crafts like pottery.) So, I felt I had to step up my game, or be lost to oblivion. I still don't think my photography compares to some of the greatest product photos out there yet, but I do think I am progressing regularly enough that I'll get there some day in the not too distant future.
I love Buckeye Burl; I love your turnings; and I love your photos!!! 👏 👏 👏 Well done.
Buckeye is one of my favs also. So much character. Your pens look Very elegant.
Nice work!
Really nice Jon. I agree, the Buckeye Burl is perfect for those!
Aye! Buckeye Burl is some of my favorite wood! In the past I have not necessarily chosen companion hardware so well. I think these two were perfectly made to match with this buckeye... This was a really intricately detailed piece, too, and it didn't quite look it from the outside. I think that's one of the things about wood I love the most...you often just never know what you are going to get! I turned a vase in 2021, one of my first, from this piece of maple that looked really janky and nasty on the outside. I picked it, because it was one of my first vases, and I figured if I screwed up it wouldn't matter given the wood. Well, once it was turned, it had the most beautiful internal staining, these little brown flecks spattered about one side of it, a slight bit of spalting in one area, and it kind of patchworked through a few different colors. In the end, the wood was truly beautiful, but you would have never known it from the outside!
Wow! Beautiful pairing, great eye for matching the wood to the kit. Your photos are beautiful as well. I'm loving that Buckeye burl, hmmm 🤔
Have you ever used Buckeye for one of your pen? If not, I may have to send oyu a piece, if I can find one long enough... Its some of the most beautiful wood around.
I have not, we are kind of just gathering a stock pile now…it's SUPER beautiful. Was the Burl stabilized or no?
This particular burl was not originally. I did, however, use GB Ultra Thin (green label) to stabilize the blank originally for trimming down to size, then as I turned it, I flooded it a couple more times. There were two cracks in teh original blank, that I am pretty sure would have resulted in the blank flying apart during turning if I had not done this. I need to get a new vacuum pump so I can properly stabilize blanks, as I have quite a lot that really need it.
I have worked with other buckeye burl that was stabilized, and its a dream to work with. That said, I do think that the stabilization resin, may not be the best for bringing out the chatoyance of the burl in the long run. Stabilizing resin doesn't seem to be quite crystal clear enough to truly do chatoyance justice. For some woods, that doesn't matter, but for buckeye burl, I think in the end it does? The chatoyance on these two pens is exquisite.
