Bottom Clearing Router Bit?
egnald
Columbus, Nebraska, USA
What do you think about putting a carbide Bottom Cleaning Router Bit in the tailstock with a round blank in a collet chuck to square the end of the blank? I thought it might work kind of like the Jim Hinze tenon cutter but across the entire face of the blank? Your thoughts???
Dave
Dave
We square the face of the flank to be square with the tube. The method you described wouldn't do that. Also router bits spin way faster than your lathe can. I don't think it would be a good idea at all.
While I agree with the squaring to the tube part, I don't think a carbide bit would be an issue with the lower speed, especially with light passes.
Thanks Ken, I wasn't thinking about a drilled blank, but a round blank being drilled for a kitless. So far I've been using a right angle sanding jig on my disc sander to clean up the end of the blank and get it at least somewhat square with it's long axis. I probably should have been more clear in my explanation. - Dave
It probably would do it if the carbides meet in the middle to get all of the blank. I use them to plow out grooves for segmenting but use a router to do it.
when I am working on bottle stoppers I use a technique that Carl Jacobson did a video on. I use a fortsner bit in the tail stock and the blank in teh jaws of the 4 jaw chuck. The bit is 3/4" or so in diameter and creates a flat spot on the bottle stopper which I use to predrill for the steel insert.
Dave
I have used a piece of plywood with a 100grit sandpaper glued on top. I used a shaft for a sanding disc intented for an angle grinder. Sandpaper is somewhat more forgiving IMO. Interesting thought however, cheers mike
