Horse Pen
See more from sorcerertd
sorcerertd
North Carolina, USA
I made this for my cousin. The barrel is spalted Tamerind, but I hit it with brown aniline dye to darken it just a little. The darker wood looks a little more appropriate to me, and added a bit more contrast throughout the blank. The top is a little proud of the hardware. I was trying to match it up with the clip, which was slightly larger than the end of the finial that meets up with the clip. I still think it looks pretty cool and I know she'll love it. It's got several layers of GluBoost medium on it, 2 layers of GlulBoost thin, then was wet-sanded/polished through the zona paper grits. This is one of the few themed kits that I liked as soon as I saw it.
20250108_105556.jpg20250108_105611.jpg20250108_105624.jpg20250108_105651.jpg20250108_105718.jpg
Looks Great. I agree that darkening the wood a little helps to give it more contrast. Did you use alcohol based aniline dye? I have struggled to use the dyes, as they seem to come off during light sanding and finishing,
View attachment 380835View attachment 380836View attachment 380837View attachment 380838View attachment 380839
Like you I'm not generally a fan of the theme pens, but this one looks very nice. You did a great job!
I did use analine dye (Keda). I haven't used it many times yet, but have found that I have to pretty much turn down to the proper diameter before I dye. If sanding/smoothing takes it just a hair below the proper diameter after that, a couple coats of CA brings it right back up to size.
